Connecting 3750 and 3650 switches together
barnmichael
I have a small network using a 24 port 3750 switch.  I need to add five computers in another room and only have one Cat 6 cable running there and no room left on the 3750.  I got a 3650 to put in the new room with the new computers.  The problem is, whenever I plug the new switch into the 3750, it shuts down the port and gives me an err-disable.  I can do a shut/no shut and re-enable the port.  I searched the web for help and read about trunking and clusters.  I'm not sure which, if either, is appropriate.  I see various documentation that shows you can put one switch behind the other.  But nothing tells me the configuration which will allow it.
Any help would be appreciated.  My Cisco knowledge is meager at best.
Michael
Michael,
The Gi1/0/8 port is currently configured for attachment of a single PC, and is specifically configured to prevent another switch from being attached.
My recommendation is to configure this port, and also the port on the 3560, as a trunk port, then create appropriate VLANs on the 3560 and assign the required ports on the 3560 to required VLANs.
The 3750 should be configured as follows (you may paste the following lines directly to the global configuration mode entered by the configure terminal command):
default interface gi1/0/8
interface gi1/0/8
  switchport mode trunk
end
The port on the 3560 should be configured in an identical way, just the port name should be changed to gi0/24.
Are you familiar with creating VLANs and assigning access ports into them?
Best regards,
Peter
9 Replies 9
Peter Paluch
Hello Michael,
We need to find out why the port gets err-disabled. It suggests an incorrect configuration. When the port is err-disabled, please issue the show int status err-disable command and post the output here.
Also, please, post the configuration of the port that gets err-disabled, and the configuration of the port on the neighboring switch. Thank you!
Best regards,
Peter
3750 error:
Port      Name               Status       Reason
Gi1/0/8                      err-disabled bpduguard
3650 port:
Switch#sh int gig 0/24
GigabitEthernet0/24 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0019.30e9.9698 (bia 0019.30e9.9698)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:02:04, output 00:02:04, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     15 packets input, 3423 bytes, 0 no buffer
     Received 14 broadcasts (0 multicast)
     0 watchdog, 13 multicast, 0 pause input
     18 packets output, 5100 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
I hope that is the configuration information you wanted.
Michael
Pardon my dyslexia, the neighboring switch is a 3560.
Michael
Hello Michael,
3750 error:
This tells you that the ports was disabled because of the BPDU Guard configured either globally or on the port. Did you configure that intentionally?
It would be best to post the configuration of the 3750 switch, or at least the configuration of the port Gi1/0/8.
Best regards,
Peter
srn-enco-sw#sho int gig 1/0/8
GigabitEthernet1/0/8 is down, line protocol is down (err-disabled)
  Hardware is Gigabit Ethernet, address is 001a.e2e8.4688 (bia 001a.e2e8.4688)
  Last input 00:52:32, output 00:52:33, output hang never
     73409090 packets input, 1888626546 bytes, 0 no buffer
     Received 12485 broadcasts (0 multicast)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 2189 multicast, 0 pause input
     312603116 packets output, 2297245927 bytes, 0 underruns
     0 output errors, 769616 collisions, 7 interface resets
Michael,
The configuration I am looking for is the output of the command
show running-config interface gi1/0/8
Thank you!
Best regards,
Peter
srn-enco-sw#show running-config interface gi1/0/8
Building configuration...
Current configuration : 335 bytes
interface GigabitEthernet1/0/8
switchport access vlan 7
switchport mode access
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
macro description cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enable
end
Michael,
interface gi1/0/8
end
Best regards,
Peter
OK, I've got the two switches working together per your  instructions.  I'm not sure if the VLANS are set up right but everything  is talking to each other as they should.  I'm using VLAN 7.
Thanks for your help,
Michael
