ip range
ealvesibm
Community Member
I'd like to know if the numbers below are on the same subnet or not.
What's the ip range on this case ?? The first and the last network address ?? Broadcast address ?
209.165.100.250/24 and
209.165.100.200/24
cadet alain
/24= 255.255.255 so last octet is for hosts and 3 first octets are for network so as the first 3 octets are the same they are indeed in the same network which is 209.165.100.0.
the broadcast address is all ones for host bits so 209.165.100.255
first usable is 209.165.100.1
last usable is 209.165.100.254
Regards.
Alain
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Yes they are in the same address block.
209.165.100.0/24:
Address range: 209.165.100.0..255
Usable addresses: 209.165.100.1..254
Broadcast: 209.165.100.255
