Connecting a Cisco Lab to a Home Router
Forgotten2852
I am working on a project for my college course. I live with several roommates and am looking for a way to connect my Cisco Lab to the internet through the Home Router. I will attach a picture of my topology. While practicing tonight, I was able to get the Cisco 2811 to ping the Home Network as well as Google. However, everything else from the L3 Switch and down was not even able to ping the Home Router. Everything from the L3 switch down is able to ping up to the Cisco 2811 Router's exit interface towards the ISP though.
Since all equipment before the Home Router is reachable to each other, I am unsure why the L3 Switch cannot reach the Home Router. I have added the default route from the Cisco 2811 Router to the Home Router (192.168.1.1). I advertised the connected 192.168.1.0 255.255.255.0 route via OSPF on the Cisco 2811 Router. I don't know what I am missing, but I feel the issue is likely something simple.
in addition to the other posts, here is what you would need to configure on the 2811 (interfaces are arbitrary since I don't know which ones you are really using):
2811
interface FastEthernet0/0
description Link to ASUS RT-AC88U
ip address dhcp
ip nat outside
interface FastEthernet0/1
description Link to L3 Switch
ip address 10.55.100.x 255.255.255.0
ip nat inside
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
access-list 1 permit 10.55.0.0 0.0.255.255
Seb Rupik
Hi there,
Is the 2811 performing NAT for all of your lab kit? If not then does the ISP modem have a route installed for the lab subnets (10.55.x.0/24) ?
Given the limitations of cheap ISP routers, the path of least resistance will be to NAT the lab subnets and overload the 2811 'outside' interface connected to the ISP router.
cheers,
Seb.
johnd2310
Level 8
Level 8
You need to tell the Home router how to get back to the Lab. You need  static routes on the Home router for the 10.551.0/24, 10.55.0.0/24 and 10.55.55.0/0 pointing to the 2811 router.
John
**Please rate posts you find helpful**
2811
ip address dhcp
ip nat outside
ip nat inside
Forgotten2852
Thanks for the valuable input, all! I've tried a hodge podge of all your responses and I am now online and internet accessible with all equipment.
Thanks again for all your help!
