Connecting a printer with static IP to vlan
Tramullo
Hello
I have this situation and Im not sure what to do, any recommendation will be very appreciate.
I have 2 vlans:
VLAN 10 has a scope of 192.168.0.0/22
VLAN 8 has a scope of 172.16.28.0/22
The switches in the the building that connect all the jacks  are default connections to VLAN 8.
I have a printer that has a static configuration of 192.168.0.147.
If all the switch ports have a default configuration as follows:
interface GigabitEthernet3/0/29
switchport access vlan 8
switchport mode access
switchport voice vlan 20
spanning-tree portfast
What would I have to change on this port configuration to allow the printer to work on the network?
Thank you and blessings.
6 Replies 6
cofee
Level 5
Level 5
Under the interface configuration change this line "switchport access vlan 8" to "switchport access vlan 10".
in addition to cofee's post,  I would also remove the voice vlan from the port. And, obviously, exclude the static IP address from the DHCP pool...that said, how is your DHCP set up ?
description Payroll printer
Reza Sharifi
In addition to Cofee's comment, You don't need the voice vlan for the port that is connecting to the printer.
So, it would look like this:
You don't really need the Switchport voice vlan on that port that the printer is on
config t
int 3/0/29
sorry I mean vlan 10 not 8
Hello
printer -  make sure it has a static ip of:
192.168.0.147
255.255.252.0
192.168.0.3.254  <---assuming this is your gateway address the same
on switch
conf t
default  interface GigabitEthernet3/0/29
no shut
switchport host
Switch & printer
make sure they are both set to the same speed and duplex setting
res
Paul
Kind Regards
Paul
