Connecting ASR to ASA???
mrbrianott
I have 1xASR 1004 and 2xASA 5585-x (Failover in Active/Standby). I'm not sure how I can succesfully connect these two devices directly. I tried a port-channel but the standby units link shows a 'susp' in the etherchannel stats on the ASR. When I do a failover the link is considered down and the ASR doesn't switch the 'bndl' link.
The connection from the ASA is a ten gig interface from each ASA directly connected to the ASR using 2 ten gig links. This is the "outside" interface of the ASA.
Any help with this would be greatly appreciated.
Edit: as pointed out (Thanks Jon) I ended up using a BDI interface. It isn't very pretty but it seems to work as intended.
ASR
bridge irb
bridge 1 protocol vlan-bridge
bridge 1 route ip
interface bdi 1
ip address 1.1.1.1
encapsulation dot1q VLANID
interface PHYSICAL
service instance 1 ethernet
encap dot1q VLANID
bridge-domain 1
on the ASA
I just created a subinterface on the physical interface so
interface tengig 0/1.$VLANID
VLAN $VLANID
ip address ...
nameif outside
worked!
Jon Marshall
I don't believe you can do this.
If the firewall pair is active/standby then you cannot create one etherchannel across both firewalls ie. each firewall would need a separate etherchannel.
See this link for details but essentially the ASAs have different system IDs so they cannot form a single etherchannel -
http://www.cisco.com/c/en/us/td/docs/security/asa/asa93/configuration/general/asa-general-cli/interface-basic.html#pgfId-1886574
basically you need a switch or switches between your router and the firewalls.
If I have misunderstood then please clarify.
Jon
Reza Sharifi
I am not familiar with how fail over works on Cisco ASA in active/standby mode, so feel free to ignore if you need to. Question, when you unplug the connection from the ASR to the active ASA, does the standby take over?
It maybe that the ASA does not fail over and that is why the link to standby ASA stays down.
I knew this but was really hoping someone might know an alternative to adding a switch between them.
