Connecting Servers to Nexus 5K
s.kanth
Hi Friends
We have 2 nexus 5K installed in our data centre recently and we are connecting new three servers to nexus switches.
Each server has 2 10GB ports . 1 port of serverA is connected 5K1 and other port is connected 5K2 ( sameway other 2 server connected to Neuxs 5K1 and 5K2 Switches).
So do we need to create each VPC with Portchannel (like VPC 1,2 and 3 ) for each server connection?
Can you please help me on this ?
Sri
You're welcome Sri
From first look configs seems are fine.
But still ou need to run some checks when you'll configure your server.
HTH,
Alex
11 Replies 11
Oleksandr Nesterov
Hi Sri
This depends from what you want to achive.
If you want to bond 2 server nics and get 20Gig link towards the server - then yes - n5ks has to run vpc. and portchannel towards the server should be configured as vpc.
But if you will run two links as active/standby on the server, or two separated links with different IPs or different vlans  - there is no need in vpc.
HTH,
Alex
HI Alex,
Thanks for your help...
Yes I want to bond 2 server NICs and get 20Gig.
But When i configured portchannel and VPC on both Nexus 5ks. I see an error message only on 5k2 as "
Consistency Check Not Performed "
interface port-channel100
switchport mode trunk
vpc 100
100    Po100       down*  failed      Consistency Check Not
But we are NOT getting any error on Nexus5k1..please suggest
Is the port on n5k2 connected to server and in up state?
Add here from both n5k
sh run vpc
sh run int po100
sh run int eth x/y - where x/y member-interface of port-channel 100
sh port-c summ
Alex
Yes servers are connected to both nexus 5Ks ,but IP address are NOT configured on 10 Gib ports at servers side.
5K1# sh run vpc
!Command: show running-config vpc
!Time: Fri Mar 16 12:16:32 2012
version 5.0(3)N1(1c)
feature vpc
vpc domain 13
  role priority 1
  peer-keepalive destination 10.*.*.* source 10.*.*.*
  peer-gateway
interface port-channel41
  vpc 41
interface port-channel51
  vpc peer-link
  vpc 100
5K2# sh run vpc
!Time: Fri Mar 16 12:16:42 2012
feature vpc
vpc domain 13
  role priority 100
  peer-gateway
  vpc 41
  vpc peer-link
  vpc 100
Port channel configuration same on both nexus..
  vpc 100
Show port-cha sum
100   Po100(SD)   Eth      LACP      Eth1/1(I)  -------- > 5K1
100   Po100(SD)   Eth      LACP      Eth1/2(I) ----------->5K2
_______________________
N5K1# sh run int eth1/1
!Command: show running-config interface Ethernet1/1
!Time: Fri Mar 16 12:25:01 2012
  channel-group 100 mode active
N5K2# sh run int eth1/2
!Command: show running-config interface Ethernet1/2
!Time: Fri Mar 16 12:25:30 2012
Check whether your vpc is up:
sh vpc
an also both member ports are in I state - that means that they don't receive lacp from the server side.
Alex
Alex,
Thanks for your help... Anyway server will be configured shotly..I will let you know the result.
I hope, our configuration is fine.
Sri
You're welcome Sri
HTH,
Alex
Sorry I see that they are trunk ports. Are any VPC up ? show vpc
Hi Alex,
Server are connected and configured. I see port channels are up and servers getting 20Gig speed now.
I would realy appreciate your help.
Sri
Hi Sri
Happy to hear that everything works now.
Have a great day.
Alex
Sri,
Are you allowing Vlan 100 on the peer-link? Based on your config this would be po 51
Jim
