03-15-2012 09:39 AM - edited 03-07-2019 05:35 AM
When having a look at the hardware rate-limit counters of one of our nexus 7010, I have noticed dropped on various class but especially layer-3 glean packets.
show hardware rate-limiter layer-3 glean
Units for Config: packets per second
Allowed, Dropped & Total: aggregated since last clear counters
Rate Limiter Class Parameters
layer-3 glean Config : 100
Allowed : 676722671
Dropped : 1115484297
Total : 1792206968
and this is increasing rather quickly. I have to admit I am not sure to understand what is really layer-3 "glean" packets so I am wondering if this kind of behaviour is normal and what can be the impact of a high number of dropped packet in that category ?
Laurent
03-15-2012 10:38 AM
Hello Laurent,
Glean is when a packet is sent to the CPU to generate an ARP entry because there is none for the destination IP of the packet. An example would be a packet where the destination IP is 192.168.1.200 when you have 192.168.1.0/24 on a vlan interface. If the PC was turned off then any packets destined to that ip address would be sent to the CPU for Glean and subject to that rate limiter.
-Matt
03-19-2012 02:35 AM
Hello Matthew,
Thanks for the reply.
So, given the high number of dropped packets in this "Rate Limiter Class" that means that very frequently the Nexus finds no arp entry for IPs and sends the packets to the CPU where they are often dropped by the limiter, right ?
Is the original packet dropped in that case or does the Nexus retries the "Glean process" until it gets a reply / exceed some timeouts ?
Laurent
03-15-2012 10:53 AM
Hi Laurent
As a fisrt step you can try to disable ip redirects on your svi interfaces.
HTH,
ALex
