Connecting switch to untagged or PC port of IP Phone
FaizanNizam
Hi all,
I have a doubt , can we connect a switch in PC/Data port & add 2 or more to PCs to it.
One of my colleague tried it , It worked . I don't know how?
Below are my doubts ,
  • Is it making a loop or broadcast storm in near future?
  • It should make a collision domain? right or wrong?
  • PC port is untagged or tagged port? If it is untagged port , then how it is communicating with switch?
  • IP Phone will strip of VLAN for any data vlan going through data/PC port? Is a reason , that all users are easily getting IP dynamically ?
  • Can i assign static IP to PC in other VLAN? Does it work?
Sample Port config:
Switch#configure terminal
Switch(config)#interface fastethernet 2/5
Switch(config-if)#switchport mode access
Switch(config-if)#Switchport access vlan 10
Switch(config-if)#switchport voice vlan 20
it might, as with any other access port.
Don't care about collision domain here. (Yes, phone creates collision domain for PC port).
Untagged - switches may be connected over access ports without any tags.
access vlan is not tagged -> phone doesn't strip anything.
No, unless your switch (connected over the phone) is running L3 routing.
