Connection backup issue.
drachen123
I respectively connected two routers with two ethernet port. one is primary and second is backup. However, after i shut down primary port. the backup mode of backup connection change to disabled instead of acting as backup... Could someone help me?
R1
interface Ethernet0/0
backup interface Ethernet0/1
ip address 172.16.1.1 255.255.255.252
half-duplex
ip address 172.16.1.5 255.255.255.252
half-duplex
R2
ip address 172.16.1.2 255.255.255.252
half-duplex
ip address 172.16.1.6 255.255.255.252
half-duplex
Situation after E0/0 shutdown
Interface IP-Address OK? Method Status Prot ocol
Ethernet0/0 172.16.1.1 YES manual administratively down down
Ethernet0/1 172.16.1.5 YES manual standby mode/disabled down
Ethernet0/2 unassigned YES unset administratively down down
Ethernet0/3 unassigned YES unset administratively down down
Kyle McKay
Using backup interfaces is primarily used for Dialup/ISDN lines, is that what you are using? Also, I do believe that a manual shutdown of the primary interface does not trigger the failover - try yanking the cable.
Secondly, if this is traditional Ethernet, you may be best using IOS SLA with tracking objects for failover.
I am using the backup on two ethernet connections. and since i am testing the topology on GNS3, i can not yank the cable. :-P and i will try use IOS SLA.
Thanks alot.
zhaoqining
Date: 2012-03-24 01:38
To: Zhao Qining
Subject: - Re: Connection backup issue.
Home
created by Kyle McKay in Getting Started with LANs - View the full discussion
Reply to this message by going to Home
Start a new discussion in Getting Started with LANs at Home
