Connection Cisco 1841 to ISP (Timewarner)
mnguyen
I have a 1841 router with 2 fast ethernet ports.  I have 1 port connected to a lan switch.  I would like port 2 to be connected to Timewarner cable for internet.  Port 2 is is configured with a static IP I got from the ISP. I also configure DNS on the router.  The problem that I am having is I can't ping the ISP's gateway.  Could some help me?
5 Replies 5
Jon Marshall
Can you -
1) post config of router
2) post "sh ip int brief" from router
Jon
Current configuration : 1065 bytes
version 12.4
hostname office
boot-start-marker
boot system flash
boot-end-marker
enable secret 5 $1$cU.D$bi3DAS9WRrDfxBWbTjDf50
no aaa new-model
ip cef
ip name-server 66.75.164.89
ip name-server 8.8.8.8
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.10.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-WAN$
ip address 67.52.116.114 255.255.255.248
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 67.52.116.113 permanent
ip http server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.20.0 0.0.0.255
control-plane
line con 0
login
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            10.10.20.1      YES NVRAM  up                    up
FastEthernet0/1            67.52.116.114   YES manual up                    up
NVI0                       10.10.20.1      YES unset  up                    up
Mark
Can you just confirm, when you say you can't ping the ISP gateway do you mean from the router or from clients or from both ?
If the clients can you change the access-list from -
to
access-list 101 permit ip 10.10.20.0 0.0.0.255 any
and then update your NAT statement to be -
ip nat inside source list 101 interface FastEthernet0/1 overload
As an aside, when you post config details on this forum if there are public addresses best not to reveal them ie people usually post -
x.x.x.113 rather than the full address you have posted. My fault for not mentioning it.
Jon
Thanks for the heads up.  I can't ping x.x.x.113
from the router.
