Connection issues when using python to connect from linux to a switch
pravinraj66
My setup :
My windows laptop -> Linux (jump host) -> Cisco switch
I have the above setup and I'm trying to connect from my laptop to cisco switch using python, I have used redispatch function in netmiko, that has some real issues.
Do we have any other way to connect?
Ruben Cocheno
@pravinraj66
You can use SSH Tunneling, check here
https://www.ssh.com/academy/ssh/tunneling-example
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
pravinraj66
Hi @Ruben Cocheno , I'm trying to achieve this in Python, I'm unable to do so.
Torbjørn
You can port forward port 22 of your switch to your localhost through your jumphost:
    ssh -L 127.0.0.1:22:{your Cisco switch}:22 {your Jumphost}
Then you can connect with python to 127.0.0.1:22
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
