01-23-2014 12:36 PM - edited 03-07-2019 05:45 PM
hello everyone i have a strange problem in my network.
i have as main switch a WS-C3560G-24TS-S, this one is connected with two fiber cables to our core. (2x4507)
well this part don't have any problem.
the problem is with the access switches that are connected to the 3560.
In total i have 24 access switches connected to this.
Port Name Status Vlan Duplex Speed Type
Gi0/1 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/2 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/3 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/4 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/5 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/6 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/7 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/8 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/9 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/10 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/11 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/12 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/13 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/14 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/15 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/16 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/17 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/18 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/19 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/20 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/21 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/22 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/23 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/24 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/25 notconnect 1 auto auto Not Present
Gi0/26 *** SEDA-PM_L3-2 * connected routed a-full a-1000 1000BaseSX SFP
Gi0/27 notconnect 1 auto auto Not Present
Gi0/28 *** SEDA-PM_L3-1 * connected routed a-full a-1000 1000BaseSX SFP
the problem is that i lose connection to some switches, for example with this one
L2_HHP-20 Gig 0/14
this switch is directly connected, and when i ping management interface .1 i have no ping loss but when i ping this switch i have ping loss.
in the logging shows nothing
Antwoord van 105.103.97.17: bytes=32 tijd<1 ms TTL=252
Time-out bij opdracht.
Antwoord van 105.103.97.17: bytes=32 tijd=6 ms TTL=252
Antwoord van 105.103.97.17: bytes=32 tijd=3 ms TTL=252
Antwoord van 105.103.97.17: bytes=32 tijd=11 ms TTL=252
Antwoord van 105.103.97.17: bytes=32 tijd=7 ms TTL=252
Antwoord van 105.103.97.17: bytes=32 tijd=10 ms TTL=252
Antwoord van 105.103.97.17: bytes=32 tijd=1 ms TTL=252
Antwoord van 105.103.97.1: bytes=32 tijd<1 ms TTL=253
Antwoord van 105.103.97.1: bytes=32 tijd=11 ms TTL=25
Antwoord van 105.103.97.1: bytes=32 tijd=1 ms TTL=253
Antwoord van 105.103.97.1: bytes=32 tijd=24 ms TTL=25
Antwoord van 105.103.97.1: bytes=32 tijd=5 ms TTL=253
Antwoord van 105.103.97.1: bytes=32 tijd=3 ms TTL=253
Antwoord van 105.103.97.1: bytes=32 tijd=2 ms TTL=253
Antwoord van 105.103.97.1: bytes=32 tijd=7 ms TTL=253
Antwoord van 105.103.97.1: bytes=32 tijd=4 ms TTL=253
Antwoord van 105.103.97.1: bytes=32 tijd=9 ms TTL=253
Anybody have an idea???
I don't have anymore.
01-23-2014 01:16 PM
What does the counters on the interface say? Have you checked the cable?
Daniel Dib
CCIE #37149
Please rate helpful posts.
01-24-2014 04:02 AM
Hello Daniel, thank you for your reply.
I will change the cables today and see if this helps.
This problem started after the employees of our utility department changed all the network cables.
here is the counter info.
GigabitEthernet0/20 is up, line protocol is up (connected)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 10/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:05, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 315990
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1427000 bits/sec, 2281 packets/sec
5 minute output rate 41634000 bits/sec, 3792 packets/sec
1479996292 packets input, 123428652935 bytes, 0 no buffer
Received 1020591 broadcasts (371068 multicasts)
0 watchdog, 371068 multicast, 0 pause input
3148285620 packets output, 3367096660734 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
i will let you know how it is after.
01-24-2014 09:45 AM
Hello all, i had one switch that was with ping loss, this switch was connected from his Gi0/1 to another switch Fa0/13
afteir i changed the cable from Fa0/13 to G0/1 i did not have any ping loss anymore.
The interface settings are auto auto.
now it is 13 Gig 0/1 164 S I WS-C2960- Gig 0/1.
i have still one switch that has ping loss, this switch is also connected from GI port to Fa port.
Do i need to set speed and duplex fixed ?
in my opinion auto should work fine.
Thank you in advanced
