ospf E1 and E2
rioneljeudy
1.- Why does the routing table for (R2) marks routes from (R1) as (E2) not as (IA) [see config and show command below]
Diagram / While marking routes from (R5) correctly [R5 running RIP]
2.- I add the following command on R1[redistribute rip metric 1 subnets] to mark traffic as TYPE-1 but routes are maked E2
R5---R1
-R2         -R3
R1
router ospf 1
log-adjacency-changes
area 1 range 8.0.0.0 252.0.0.0
redistribute connected subnets
network 1.1.1.1 0.0.0.0 area 0
network 8.0.0.0 0.0.0.255 area 1
network 9.0.0.0 0.0.0.255 area 1
network 10.0.0.0 0.0.0.255 area 1
network 11.0.0.0 0.0.0.255 area 1
network 172.12.123.0 0.0.0.255 area 0
neighbor 172.12.123.2
neighbor 172.12.123.3
router rip
version 2
redistribute connected metric 1
redistribute ospf 1 metric 1
network 15.0.0.0
no auto-summary
R2
router ospf 1
network 2.2.2.2 0.0.0.0 area 2
R5
router rip
version 2
network 4.0.0.0
network 5.0.0.0
network 6.0.0.0
network 7.0.0.0
network 15.0.0.0
Routing table of (R2)
R2#sh ip route ospf
     1.0.0.0/32 is subnetted, 1 subnets
O       1.1.1.1 [110/65] via 172.12.123.1, 00:44:32, Serial0/0
     33.0.0.0/32 is subnetted, 1 subnets
O IA    33.33.33.33 [110/65] via 172.12.123.3, 00:44:32, Serial0/0
O IA    3.3.3.3 [110/65] via 172.12.123.3, 00:44:32, Serial0/0
O E2 4.0.0.0/8 [110/1] via 172.12.123.1, 00:44:32, Serial0/0
O E2 5.0.0.0/8 [110/1] via 172.12.123.1, 00:44:32, Serial0/0
O E2 6.0.0.0/8 [110/1] via 172.12.123.1, 00:44:32, Serial0/0
     172.34.0.0/24 is subnetted, 1 subnets
O IA    172.34.34.0 [110/74] via 172.12.123.3, 00:44:32, Serial0/0
O E2 7.0.0.0/8 [110/1] via 172.12.123.1, 00:44:32, Serial0/0
     8.0.0.0/32 is subnetted, 1 subnets
O E2    8.1.1.1 [110/20] via 172.12.123.1, 00:44:32, Serial0/0
     9.0.0.0/32 is subnetted, 1 subnets
O E2    9.1.1.1 [110/20] via 172.12.123.1, 00:44:32, Serial0/0
     10.0.0.0/32 is subnetted, 1 subnets
O E2    10.1.1.1 [110/20] via 172.12.123.1, 00:44:32, Serial0/0
     11.0.0.0/32 is subnetted, 1 subnets
O E2    11.1.1.1 [110/20] via 172.12.123.1, 00:44:34, Serial0/0
     14.0.0.0/32 is subnetted, 1 subnets
O E2    14.14.14.14 [110/20] via 172.12.123.3, 00:44:34, Serial0/0
     15.0.0.0/24 is subnetted, 1 subnets
O E2    15.0.0.0 [110/20] via 172.12.123.1, 00:44:34, Serial0/0
Rolf Fischer
Level 9
Level 9
1) Can you check if the network/wildcard-masks cover the desired interfaces (show ip ospf interface brief) on R1?
2) You have to use the metric-type 1 option in the redistribute-command. Metric 1 sets the seed metric to 1 (default: 20).
Rolf
Rolf Fischer
Level 9
Level 9
Rolf
