Connection Problem with vlans
qus83
Hi Everyone
i have question i hope someone can help me with
i have ws-c2960x-24td-l stack switches for our customer
 I have configured new VLAN (VLAN 53)  same way as (VLAN50 & VLAN51) as requested from customer ,and now they informed me that one of the servers moved from VLAN50 to VLAN53 and will make new virtual servers in future  (VLAN 53) and needs to be allowed to access from both of them ?
as i know The separate VLANs must communicate through a layer-3 device (Routers) which is located in ISP
If the host on one VLAN wants to communicate  to a host on another VLAN, it must perform the routing between them.
So in order to perform that ,shell i contact ISP to do that or make NAT or ROUTING in Firewall
 i have no experance with FW so your help please
7 Replies 7
Seb Rupik
Hi there,
Ask you ISP to configure a SVI for the VLAN at the local router. Looking at your topology this router should advertise the new subnet to other routers via an IGP (OSFP, EIGRP?) to provide access.
Unless you require remote access to the new server VLAN then there will be no need to adjust the firewall configuration.
cheers,
Seb.
Hi   Seb Rupik
 thanks for your reply
 if i ask the ISP to do the routing so i don't need to configured anything in firewall cuz for vlan 50 and 51 they are configured inside fw ???
keanej
Level 3
Level 3
So... You have Vlan 50 / 51  and 53
What are the default gateways on all the devices in these vlans ??
Lets say - they are 192.168.50.1 / 192.168.51.1 and 192.168.53.1
Are these all on different sites ?? Seems that two of the vlans are on the same site.
If they are on the same site and the router is the default gateway for both - they will communicate without and issue.
Ideally you should have different Home Subnets on all the different sites - otherwise it will get confusing.
So lets say its configured like this...
Site 1 = Vlan 50 - 192.168.50.0/24
Site 2 = Vlan 60 - 192.168.60.0/24
Site 3 - Vlan 70 - 192.168.70.0/24
Site 4 - Vlan 81 - 192.168.80.0/24
Vlan 81 - 192.168.81.1/24
If you have hosts/machines in different sites communicating - you will needs to allow inbound communication between the sites - this would typically be done using Site-to-Site VPNs.
To get this working - you need DNS entries locally on each site for the remote machines.
The router then has two routes - one for default (internet) and one for the other site.
This second route points to the Site to Site VPN.
If its a HQ / Branch situation - which it often is - then you would have - 3 Site to Site VPNs
HQ to Site 1 / HQ to Site 2 and HQ to Site 3 -
Im presuming your double vlan is the HQ.
Anyway - hope that helps
James
You configure the switchport to trunk und allow both VLANs on that port. The Serverside admin has to enable trunking on its own side to tag the VLANs. This is the usual way to to host virtualized hosts on one switchport. This way the virtualized Server can communicate to the ISP gateway directly.
Hi  RabbitSchpaenningtri
Thanks for your reply
i already configured them as trunk allowed the two vlans in same portchannels
but how can the The Serverside admin enable trunking on its own side to tag the VLANs ???
can you explain that in more details please ??
qus83
below you can find the switch configuration , might be helpful to understand what i mean
and please inform me if something missing or need to be changed its same like config that i have
vlan 50
 name Groun
vlan 51
 name GLeem
vlan 53
 name Glees
vlan 52
 name Test
interface Port,channel1
 switchport access vlan 50
 switchport mode access
 spanning,tree portfast
 spanning,tree bpduguard enable
interface Port,channel2
 switchport trunk allowed vlan 1,50-53
 switchport mode trunk
 spanning,tree portfast trunk
interface Port,channel3
interface Port,channel4
interface Port,channel5
interface Port,channel6
interface Port,channel7
interface Port,channel8
interface Port,channel9
interface Port,channel10
interface Port,channel11
interface Port,channel12
interface GigabitEthernet1/0/1
 spanning-tree portfast
 spanning-tree bpduguard enable
 channel-group 1 mode on
interface GigabitEthernet1/0/2
 spanning-tree portfast trunk
 channel-group 2 mode on
interface GigabitEthernet1/0/3
 channel-group 3 mode on
interface GigabitEthernet1/0/4
 channel-group 4 mode on
interface GigabitEthernet1/0/5
 channel-group 5 mode on
interface GigabitEthernet1/0/6
 channel-group 6 mode on
interface GigabitEthernet1/0/7
 channel-group 7 mode on
interface GigabitEthernet1/0/8
 channel-group 8 mode on
interface GigabitEthernet1/0/9
 channel-group 9 mode on
interface GigabitEthernet1/0/10
 channel-group 10 mode on
interface GigabitEthernet1/0/11
 channel-group 11 mode on
interface GigabitEthernet1/0/12
 channel-group 12 mode on
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
 switchport access vlan 53
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
 description Support port i VLAN 50
interface GigabitEthernet1/0/53
interface GigabitEthernet1/0/19
 shutdown
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
 shutdown
 spanning-tree bpdufilter enable
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface TenGigabitEthernet2/0/1
interface TenGigabitEthernet2/0/2
interface Vlan1
 ip address 192.168.1.254 255.255.255.0
interface Vlan52
 ip address 192.168.52.254 255.255.255.0
interface Vlan50
 ip address 192.168.50.254 255.255.255.0
interface Vlan51
 ip address 192.168.51.254  255.255.255.0
interface Vlan53
 ip address 192.168.53.254   255.255.255.0
ip default-gateway 192.168.50.1
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 8.8.8.8 255.255.255.255 192.168.1.1
ip route 192.168.0.0 255.255.0.0 192.168.1.1
ip route 192.168.0.0 255.255.0.0 192.168.50.1
ip route 192.168.0.0 255.255.0.0 192.168.51.1
ip route 192.168.0.0 255.255.0.0 192.168.53.1
ip route 192.169.0.0 255.255.0.0 192.168.1.1
ip route 192.169.0.0 255.255.0.0 192.168.50.1
ip route 192.169.0.0 255.255.0.0 192.168.51.1
ip route 192.169.0.0 255.255.0.0 192.168.53.1
ip route 200.55.120.21 255.255.255.255 192.168.50.1
ip route 400.60.20.22 255.255.255.255 192.168.1.1
ip route 192.168.25.0 255.255.255.0 192.168.1.1
ip route 192.168.25.0 255.255.255.0 192.168.50.1
ip route 192.168.25.0 255.255.255.0 192.168.51.1
ip route 192.168.25.0 255.255.255.0 192.168.53.1
