Connection refused ssh catalyst 6509
brad.thurston
Community Member
I am having an issue with our cat6509 switch, running ios not catos. I am unable to make a ssh connection. I verified the settings look fine. I checked to make sure i didnt have any hung sessions. That looks fine also. Anyone ever have a similar problem? Not sure where to check next.
5 Replies 5
Amit Singh
Brad,
Please paste the switch configuration. If SSH is configured properly, have you allowed it on the VTY lines. Please do the following:
config t
line vty 0 4
transport input all or transport input ssh
HTH,
-amit singh
That was already done. I am posting partials here:
This is what i'm seeing for users
car01>show users
Line User Host(s) Idle Location
* 0 con 0 admin idle 00:00:00
1 vty 0 idle 3w0d 88.42.170.195
2 vty 1 idle 3w0d 88.42.170.195
3 vty 2 idle 6w0d 60.18.161.58
4 vty 3 idle 3w0d 88.42.170.195
5 vty 4 idle 3w0d 88.42.170.195
here are some parts of the config:
ip ssh time-out 30
ip ssh authentication-retries 2
ip ssh source-interface GigabitEthernet9/48
line con 0
line vty 0 4
access-class 100 in
password 7 ***************************
transport input ssh
I am unable to kill the vty idle connections
Did you try "clear line vty X " command ? May be a bug .
Brad,
Have you generated your crypto key. Please refer to the following url for the SSH configuration steps.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/120s5/sshv1.htm#wp18428
Hope this helps,
