Connectivity issue between Cisco catalyst and Dell Force10 E-300
vishwajeett1
Hi All,
I am facing a packet loss issue for few public ip's of around 40-60%.
I have force 10 core router for eBGP peering and below which lies my cisco catalyst C6509-NEB-A.
A TenGigabitEthernet connets the two port. Two subinterfaces. I will paste the config below.
Traceroute shows some strange packet drops between catalyst and Force10.
The bunch of intermittent IP's and working ip's are learning the same route via E-300 via IBGP.
Following are different running configs and routes learned collected from Catalyst:
TenGigabitEthernet2/2      unassigned      YES NVRAM  up                    up
TenGigabitEthernet2/2.2007   2tow_E3008    YES NVRAM  up                    up
TenGigabitEthernet2/2.2012    unassigned      YES unset  up                    up
TenGigabitEthernet2/2.2024    10.16.0.113     YES NVRAM  up                    up
TenGigabitEthernet2/2 is up, line protocol is up (connected)
  Hardware is C6k 10000Mb 802.3, address is xxxxxxxxxxxxxxxxxxx
  Description: cr1002.snv1:xg0/0, 10GE
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s
  input flow-control is on, output flow-control is on
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 05:57:35
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 20859000 bits/sec, 6788 packets/sec
  5 minute output rate 56522000 bits/sec, 8922 packets/sec
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     138879419 packets input, 56747867539 bytes, 0 no buffer
     Received 10319 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     187724775 packets output, 145812194266 bytes, 0 underruns
TenGigabitEthernet2/2.2007 is up, line protocol is up (connected)
  Hardware is C6k 10000Mb 802.3, address is xxxxxxxxxxxxxxxxxxxxxx
  Description: cr1002.snv1:xg0/0.2007, dot1q subif, 2tow_E3008/30
  Internet address is 2tow_E3008/30
  Encapsulation 802.1Q Virtual LAN, Vlan ID  2007.
ag1001.snv1#
ag1001.snv1#sh ip route 207.86.215.17
Routing entry for 207.86.215.0/24
  Known via "bgp myAS", distance 200, metric 0
  Tag ISPAS, type internal
  Last update from 6eBGPpeer49 04:27:39 ago
  Routing Descriptor Blocks:
  * 6eBGPpeer49, from 2.LoopE300.4, 04:27:39 ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag ISPAS
ag1001.snv1#sh ip rou 198.173.3.56
Routing entry for 198.172.0.0/15, supernet
  Last update from 6eBGPpeer49 04:27:59 ago
  * 6eBGPpeer49, from 2.LoopE300.4, 04:27:59 ago
      AS Hops 2
      Route tag ISPAS
where 198.173.3.56 is the pingable ip and 207.86.215.17 is the troubled one.
Please let me know what else is required.
7 Replies 7
Reza Sharifi
Not familiar with Force10, but the Cisco 6500 appears to be running in layer-2 only with trunk connecting to the Force10. Can you post trace routes to the same IPs from the Force10 router?
What is the output of:
sh run int te2/2.2007, 2012 and 2024?
Hi Reza,
Trace route is clear and pings are all success from force10.
Below is the required output:
te2/2.2012 can be removed, but I dont think that could be an issue as it has nothing configured, roght?
interface TenGigabitEthernet2/2.2007
 description cr1002.snv1:xg0/0.2007, dot1q subif, 208.xx.xx58/30
 encapsulation dot1Q 2007
 ip address 208.xx.xx.58 255.255.255.252
 no ip proxy-arp
 ip ospf message-digest-key 1 md5 7 xxxxxxxxxxxxxxx
 ip ospf network point-to-point
 ip ospf cost 5
end
ag1001.snv1#sh run int te2/2.2012
Building configuration...
Current configuration : 44 bytes
interface TenGigabitEthernet2/2.2012
end
ag1001.snv1#sh run int te2/2.2024
Current configuration : 321 bytes
interface TenGigabitEthernet2/2.2024
 description cr1002.snv1:xg0/0.2024, dot1q subif,  10.xx.xx.113/28
 encapsulation dot1Q 2024
 ip vrf forwarding MGMT
 ip address 10.xx.xx.113 255.255.255.240
 no ip proxy-arp
 standby 1 ip 10.xx.xx.126
 standby 1 priority 105
 standby 1 preempt
 standby 1 authentication xxxxxxx
end
Where is the gateway for the user (LAN) side located? Is it on the 6500?
Are you doing OSPF between Force10 and the 6500?
Do you have 2 6500 and 2 Force10 or just one of each?
Can you post "sh run" from the 6500?
Also, can you do a trace route and ping to 8.8.8.8 from the 6500 and post the results?
Yes, we have 2 6500's and 2 Force10's.
We are using OSPF internally.
But the things being shared is from the primary of the 6500's. Also, there is no uplink from the other Force10, so it is not advertising any external routes.
the gateway to all internal user is this catalyst..
Tracing the route to google-public-dns-a.google.com (8.8.8.8)
  1 vl2007.cr1002.snv1 (20x.xx.17.57) 0 msec 0 msec 16 msec
  2 6x.xx.xx49 [AS 3561] 0 msec 0 msec 0 msec
  3 hr2-v3059.sc8.savvis.net (209.1.56.9) [AS 3561] 0 msec 0 msec 0 msec
  4 er1-te-7-0-1.SanJoseEquinix.savvis.net (204.70.200.213) [AS 3561] 0 msec 16 msec 4 msec
  5 sjp-brdr-05.inet.qwest.net (63.235.40.205) [AS 209] 0 msec 4 msec 0 msec
  6 snj-edge-04.inet.qwest.net (67.14.34.86) 0 msec
    snj-edge-04.inet.qwest.net (67.14.34.82) 0 msec
  7 65.113.96.130 [AS 209] 4 msec 4 msec 0 msec
  8 66.249.95.63 [AS 15169] 4 msec
    209.85.244.25 [AS 15169] 4 msec
  9 216.239.49.89 [AS 15169] 4 msec
    216.239.49.97 [AS 15169] 4 msec
    216.239.49.93 [AS 15169] 4 msec
 10 google-public-dns-a.google.com (8.8.8.8) [AS 15169] 4 msec 0 msec 4 msec
I am learning same MAC addresses on Force10 of the two catalyst switches on different VLAN's
Could that be causing issue for the packet drops?
Internet 20x.xx.x7     -        00:01:e8:5e:8c:35        - Vl 2007 CP
Internet 20x.xx.x8    39      00:1c:0f:5d:86:00           Te 0/0 Vl 2007 CP
Internet 20x.xx.x1     -        00:01:e8:5e:8c:35     -    Vl 2008 CP
Internet 20x.xx.x2   224     00:1c:0f:5d:76:80           Te 0/1 Vl 2008 CP
One more thing,
The ip's which we were unable to ping from catalysts are now pingable, but getting packet loss for other ip's  now.  They were down for approximately  two days. That's not even for block's but some random public ip's!
Hi Reza,
The issue got resolved by itself, RFO is still unknown.
Can lack of FIB table cache be the reason for some ip's to be intermittent?
We found the cache is of 512k whereas we are learning around 550k routes through BGP peer.
