Console access to stacked 9300L series running 16.12.1
We have stacked 9300L series switches, when we used console port to access the switches it gave us the login, but could never get into the switch. We connected the console cable to the console port on the master switch and we could login to the switch. Is this normal behavior for stacked 9300L series switches?
Reza Sharifi
You should be able to console to the member switch, if not try enabling it and test again.
Examples
This example shows how to enter the redundancy main configuration submode and enable the standby switch:
Device(config)# redundancy
Device(config-red)# main-cpu
Device(config-r-mc)# standby console enable
Device#
 https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/command_reference/b_169_9300_cr/stack_manager_and_high_availability_commands.html#wp1450072206
