console authorization on Nexus 7000 switch not working
baghimir
I'm trying to enable command authorization for ssh as  well as console access to a Nexus 7010 box (version 5.0). Following is  the config:
aaa group server tacacs+ ACS5-1
    server 10.12.19.11
    server 10.12.19.12
    source-interface loopback0
snmp-server enable traps aaa server-state-change
aaa authentication login default group ACS5-1 local
aaa authorization config-commands default group ACS5-1 local
aaa authorization commands default group ACS5-1 local
NX# sh aaa authentication
         default: group ACS5-1
         console: group ACS5-1
NX#
NX# show aaa authorization
         pki-ssh-cert: local
         pki-ssh-pubkey: local
AAA command authorization:
         default authorization for config-commands: group ACS5-1 local
         default authorization for commands: group ACS5-1 local
As  you can see, the default group configuration ACS5-1 for authenticatoin  has applied to both defaults and console. But the command authorization  does not appear to be applied to the console. As a result, when i login  from the console and get authenticated, the command authorization does  not trigger and i can run commands I'm not supposed to. In the  configuration, I do not see "aaa authorization console" option unlike we  have in IOS.
Anything i'm missing ? please help.
phiharri
Hey Badri,
Check the documentation:
"For Cisco NX-OS Releases 4.x and 5.x, command authorization is available only for non-console sessions."
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/security/configuration/guide/Cisco_Nexus_7000_NX-OS_Security_Configuration_Guide__Release_5.x_chapter6.html
Command authorization for console sessions is coming in NX-OS 6.x.
Hope this helps,
/Phil
Hi baghimir
have you resolved this issue yet  ? as I had similar issue like you , but I cannot get the local user pass for authentication via by console interface .
we're running 5.1(3)  , do you think it was bugs on this version ?
Justin
