command to check 6500 switch performance or resource usage
Difan Zhao
Level 7
Level 7
Hi experts,
I am on a call right now troubleshooting some latency issue. The CPU usage on the sup card is low. Don't see any drops or input errors. I am aware that the switch and its modules have capability limits. Is there command I can run which will tell me if any module is overloaded or if the fabric/backplane is over utilized?
My chassis is WS-C6513 and sup card is WS-SUP720-3B
Thanks!
InayathUlla Sharieff
The following commands would be usefull to you:
6500#show platform hardware capacity fabric
6500#show platform stats
Inayath
Jeff Orr
Level 2
Level 2
Show platform hardware capacity fabric
show sys (some iOS versions)
Inayath
Difan Zhao
Level 7
Level 7
Thank you guys. You posts have been rated.
