Console Message "mifs ifs_read 0 bytes"
MaxFisher925
We recently acquired some WS-C2960S-48FPS-L switches.  Almost every one of the switches shows this message on the console when connected via console cable.  Is this benign?
Switching, Catalyst 2000
switch#mifs ifs_read 0 bytes
marce1000
   - Try fsck flash: and or use latest advisory software release , check if  that can help : https://software.cisco.com/download/home/282864101/type/280805680/release/15.2.2E9
 M.
as far as I recall. anything 'ifs' refers to the integrated file system, which is basically the name for all the file systems available on your switch (you can display those with the exec commands 'showfilesystems/show file system/show file descriptors).
The document below is an interesting read:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ifs/configuration/15-s/ifs-15-s-book/ifs-using.html
