Console noise
When using a ISR 4221 as a console device. I get the following on one of the 3850's and it will not stop scrolling..  I even removed and added back. I do see a lot of noise!!.. any suggestions would be helpful.
* 0/1/6    8 TTY   9600/9600  -    -      -    -    -     4   2015    0/0      -
no ip host GSCSWS 2008 10.0.1.1
SCProdSw1>GSCOOB1>GSCProdSw1>
% Bad IP address or host name% Unknown command or computer name, or unable to find computer address
GSCProdSw1>
GSCProdSw1>$mmand or computer name, or unable to find computer address
% Bad IP address or host name% Unknown command or computer name, or unable to fi^nd computer
Reza Sharifi
Do you have the correct host entry?
Example:
ip host testrouter 10.10.10.10
Also, can you clear the session and try again?
HTH,
I have 9 other devices and this is the only one giving me an issue.I have
tried multiple times to clear that line and even remove the line from the
config and still does not help. If I unplug and then plug back in the
device then the issue goes away for a very short time, just enough for me
to get into the device.
