07-07-2016 02:37 AM - edited 03-08-2019 06:31 AM
Hi All,
is there any way to use console port as Ethernet port, please tell me
07-07-2016 03:03 AM
Unfortunately, no, that is not possible. The Ethernet operates entirely differently from a RS-232 console port, using different pins, different signals, different data organization. The integrated circuit that handles the console port operates as a RS-232 controller only, and it is not possible to switch it to Ethernet operation.
I am sorry to disappoint you.
Best regards,
Peter
07-07-2016 06:10 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just as an aside, some devices also provide Ethernet management ports. However, they aren't the console.
If you do need Ethernet "console" access, you can obtain that using another device. For example, I've done that with a pair of routes that had both serial AUX ports and the console port. I.e. connect one device's AUX to the other device's console port. (This assuming both devices also have Ethernet connectivity.)
You might also obtain Ethernet "console" access using some form of terminal server. I often have someone connect a PC to the device's console port, while the PC has Ethernet access, and then I remote access the PC, allowing me remote console access, using Ethernet.
