Console Speed
stefanmoore
Community Member
The console speed on my 3750G-48-TS refuses to stay at 9600, it wants to default to 115200 for some reason. Even after doing:
conf t
line con 0
speed 9600
(open new hype term---9600-8-N-1)
end
wr m
it still default to 115200 what else can I do here?
8 Replies 8
Richard Burts
Stefan
You might want to check the setting of the configuration register and make sure that it is not specifying the higher speed. I have had the experience where a device would not keep the speed that I set under line con 0 and it turned out to be a setting in the configuration register.
Rick
Rick
How would I check that out?
Stefan
I have done some research and found a suggestion that the speed can be set using the bootloader. Perhaps you might try this suggestion:
Go into the bootloader by power-cycling the switch and holding down the “Mode” button. Enter the command “set BAUD 9600″ Then type “reset” to reboot the switch.
Rick
Rick
I might have done this already, but its worth another shot!
Nice one Rick (+5).  Another command to the "set BAUD <#>" is the "unset BAUD".
At Rommon you may try:
switch:BAUD=9600
Raj.
change the conig register to 0x2102 and baud rate under consle to 9600 and then check.
richard_artes
Level 2
Level 2
Fantastic, worked for me, you are a *
