console
saquib.tandel
Level 7
Level 7
Hello
I would like to inquire if there is a way to disable password reset option via console on 2800 and 2900 series router
thanks
ST
You can configure "no service password-recovery":
http://www.cisco.com/en/US/partner/docs/ios/sec_user_services/configuration/guide/sec_no_svc_pw_recvry.html
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
