Controller redundancy
Lawrence Desmarais
Community Member
Hi @All
I've got controller with dual port, who acts like an unmanaged switch, they are visible if they are in access mode. they want to connect each port of my controller to two different switches c9300-24t on the same vlan. I have to use RSTP.
All I've got so far is flapping or flooding.
Is it possible?
What kind of configuration do i need to make it work?
I've tried a lot of configuration
regards,
6 Replies 6
run bdpuguard in Port of Both SW
if the Controller by chance forward the BPDU then the port will go to err-disable and then you will know that you can not connect it to both SW
if NO and you only see mac flapping then it OK (not optimal but it oK)
MHM
When my ports are flapping, I lose the connection with my controller. Which is not ok.
what is SW you have Nexus ?
MHM
My VLAN is composed of Catalyst C9300-24t and C9300-48t.
The PO from controller to both SW impossible.
The SW need to be stack to config PO.
Can you ask controller team if then can config one link primary and other as backup.
MHM
Lawrence Desmarais
Community Member
is it possible to use Eterchannel for the same application? The conception team want to connect many controller who mesh it out into many switches.
