Conversion of Dell switches config to Cisco Catalyst config
kashif.ahmad
Hi all,
We are moving from Dell Switches to Cisco Switches. I have the config from dell switches I was just wondering if there is any way I could convert these config files so that it get compatible on cisco switches. (syntax wise)
thanks,
Kashif Ahmad
7 Replies 7
Mark Malone
There is no actual tool like the tool for ios conversion to nx-os or the ASA tool converters but if you post the config should not be that hard to convert it to Cisco
Tool page
http://www.cisco.com/c/en/us/support/web/tools-catalog.html
here is the complete config. any help would be greatly appreciated.
thanks
Just to get you started ,your stacking with Cisco will work automatically once the software versions are the same , you can set a master if you choose too though
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swstack.html#pgfId-1106477
I have changed some of the config to Cisco as below examples , I will do a bit more shortly
Etherhcannel
po1
switchport mode access
inter gig 0/1
channel-group 1 mode active
inter gig 0/2
Access port
inter gig 0/3
spanning-tree portfast
sapnning-tree bpduguard
switchport access vlan 200
Trunk port
inter gig 0/4
switchport mode trunk
switchport trunk allowed vlan allowed 1,10,15,20,100-108,200,1000
SNMP is same as Cisco
spanning-tree portfast bpdufilter default--dont use bpdufilter in Ciosco or it will turn off STP an
Cisco password setup --basic
enable secret xxxxxxxxxxxxxxxxxxxxxxxxxxxx
username Mark secret xxxxxxxxxxxxxxxxxxxxxxxxxxxx
Line vty 0 4
transport input ssh
login local
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh source-interface xxxxxxx
ip ssh version 2
 generate rsa keys for ssh
(conf t) crypto key generate rsa  ------then hit return and type 1024 and return again to geerate the rsa key , then check below to make sure its enabled
show ip ssh
CREATE VLAN AT LAYER 2 CISCO
vlan 226
name test vlan
Create vlan LAYER 3 ---DHCP Helper address goes under vlan
interface Vlan226
 description NETMGMT in Belgium
 ip address 172.16.44.20 255.255.255.240
 IP HELPER ADDRESSS X.X.X.X
static routes would be the same as Cisco
ip route 192.168.15.0 255.255.255.0 10.10.10.4
There  are a few ways to do ospf but this one below maybe the easiest through the process
http://study-ccna.com/ospf-configuration/
advertise every local subnet under the process , give the process a router id usually use a loopback if available you can always create 1
ip name-server and logging/hostname  is same as Cisco
Thanks Mark, this is a big help. I have a few questions about the following commands on the dell switch:
what are these for?
1. vlan routing 20 1
    vlan routing 100 2
2. ip address 10.10.1.3 255.255.255.0
ip address vlan 10
ip domain-name md52.mdambulance.comq
ip name-server 192.168.100.1
ip name-server 192.168.100.19
logging console error
logging file debug
logging buffered debug
logging 10.10.1.155
level debug
3. these helper-address should go under what vlan? since these are configured globally on dell switch.
ip helper-address 192.168.100.1 time
ip helper-address 192.168.100.19 time
4.would it be ok if I install the ntp instead of sntp?
sntp unicast client enable
sntp server 192.168.100.1
sntp server 192.168.100.19 priority 2
clock timezone -6 minutes 0
Thanks again
im not a Dell guy so if im wrong here Paul can hopefully correct me ,
1 I googled this --it just looks like it enables the particular vlan for routing
http://en.community.dell.com/support-forums/network-switches/f/866/t/19427798
On a Cisco switch all you do for all vlans is make sure in global config ----ip routing --- is enabled that exact command
2 For Cisco
logging console
logging monitor
logging buffered 7
logging 10.10.1.155
ip name-server 192.168.100.1 --same as Cisco
3 Exactly in Cisco each vlan must be notified under its interface if it needs a helper its not  global command
4 Of course use NTP no issues there
ntp server x.x.x.x prefer
ntp server x.x.x.x
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
Hello
The Dells are very similar to the Cisco ios -Ive recently being doing work on some 2048P and N3024 switches and to me the ios is like a light version of cisco.
Personally you shouldn't have to much trouble moving over the config
res
Paul
Kind Regards
Paul
If anyone is willing to help with a Dell to Nexus QOS config conversion, it would be a great help.
