convert switchport to routerport on 6500
Athiqur Rahman
On the supervisor card of a cisco 6500 series, according to the following link,
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856.html
it only has 2 uplink ports on the card. Would I be correct in assuming that I only have those to ports that I can configure IP addresses on?
The cisco that is being devlivere is coming with a 48 port switch and 24 port fibre switch. Could I change any of those ports into a router port and configure IP addresses on those?
The supervisor card is a ws-sup-720-3b
the 48 port switch is a ws-x6748-ge-tx
the 24 port fibre switch is ws-x6724-sfp
glen.grant
   Every one of those ports can be a routed port  or   a SVI  (L3)  routed port.  The beauty of a multilayer switch..
Or  This is used if you need the same subnet down multiple ports ..
interface vlan 10
ip address 192.168.10.1 255.255.255.0
int g1/1
switchport
switchport mode access
switchport access vlan 10
Leo Laohoo
interface
no switchport
ip address 1.2.3.4 255.255.255.0
no shut
glen.grant
interface vlan 10
int g1/1
switchport
thanks for the quick response guys
