convert VSS in mode standalone
sdurn
I need to undo a VSS and i have a doubt about the process, somebody has did it this before?
if I run:
1 .- in current active switch (switch1)
convert standalone mode switch
configuration related VSL and modules related to the switch 2 is deleted?
2.-record the configuration and restart the device (switch 1).
3 .- chassis standby (switch2) becomes active. I recover the Console so I can run:
4.- wr and reload switch2
5.-Once I have the two devices in standalone mode , just I have to execute: accept mode virtual switch?
or I have to re-configure the Switch ID switch domain, priorities ... in two devices ?
I need to pass over all process to convert two standalone devices in VSS:
convert virtual switch mode and finally switch accept mode virtual
thanks
0 Replies 0
