09-26-2007 11:05 AM - edited 03-05-2019 06:43 PM
Does anyone know/has where I can get the steps to convert catos to ios for a 4000 series catalyst.
I searched everywhere no luck so far.
thank you
09-26-2007 11:15 AM
Check this link
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml.
Just did this last night on a 6500 with Sup32.
09-26-2007 11:31 AM
thank you for your reply.
is the conversion for 4000 series the same as in 6500 MSCF?
thank you.
09-26-2007 11:23 AM
You cannot change a 4000 switch to IOS . You must have at least a Sup II plus supervisor to run IOS which it comes with . No catos conversion for the older 4006 series with a Sup 2 .
09-26-2007 12:11 PM
I am working with a Catalyst 4003 series.
Model: WS-C4003
supervisor engine WS-X4012.
09-26-2007 03:50 PM
Can't do it with that thats even older than a Sup II . Catos only for that model . Only the newer sup's from Sup II plus up to Sup V run IOS and those ship from the factory with IOS. Earlier versions like yours cannot be converted.
09-26-2007 06:11 PM
Glean,
Thank you for your replies. I appreciate your help.
