Converting VLan configuration from HP ProCurve Switch 2510G-24 to Cisc
Hi, can anyone convert these Vlans configuration from HP switch to Cisco switch?? Cause I'm getting really confused about tagged untagged and no untagged on hp switch. I've been googling about that but still my brain did not get it.
vlan 1
name "DEFAULT_VLAN"
untagged 6,22
ip address dhcp-bootp
no untagged 1-5,7-21,23-24
exit
vlan 2
name "Lt.2"
tagged 1-2,4,6-7,10-11,17,20,22-24
exit
vlan 3
name "Lt.3"
tagged 1,3-4,6-7,10-11,17,20,22-24
exit
vlan 4
name "Lt.4"
untagged 5,8-9,12-14,17,21,23
tagged 1,4,6-7,10-11,20,22,24
exit
It's from backed up configuration with putty tho. Thanks for the help
basically, on the HP, 'untagged' means host port, and 'tagged' means trunk. I have come up with the conversion below, not sure if it is all correct, but basically, if you look at this:
vlan 4
name "Lt.4"
That means ports 5,8-9,12-14,17,21,23 are access ports in Vlan 4. The tagged ports are trunk ports that carry Vlan 4.
interface GigabitEthernet0/1
switchport mode trunk
switchport trunk allowed vlan 2
interface GigabitEthernet0/2
interface GigabitEthernet0/3
switchport trunk allowed vlan 3
interface GigabitEthernet0/4
switchport trunk allowed vlan 2,3,4
interface GigabitEthernet0/5
switchport mode access
switchport access vlan 4
spanning-tree portfast
interface GigabitEthernet0/6
switchport access vlan 1
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface Vlan 1
ip address dhcp
Hello
Cisco
conf t
vlan 2-11,17,20-24
exit
int vlan 1
ip address dhcp
no shut
access ports 5,8-9,12-14,17,21,23
int x/x
switchport host
no shut
int x/1
int x/2
switchport trunk allowed vlan 1,2,4
int x/3
switchport trunk allowed vlan 1,3
int x/4
switchport trunk allowed vlan vlan 1-4
int ran x/6
int ran x/7
int ran x/10 -11
int x/17
int x/20
int ran x/22 -24
Kind Regards
Paul
Jerome BERTHIER
Please here few explanations on HPE vlan tagging rules :
https://techhub.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8156_wb_2926_atmg/content/ch01s02.html#s_VLAN_tagging_rules
To my understanding, "tagged" means that the port is configured as trunk and 801.Q tagged frames are accepted against vlans number matching the port config. "Untagged" means that 801.Q trunking is not applied. So, frames do not use vlan marking and are accepted to the vlan associated with the port.
"No untagged" means that this vlan is not usable as untagged traffic on port. I think that is a way to disable non tagged traffic on the port. On Cisco Catalyst, it is equivalent to disable the native vlan.
So, if we look at your HP configuration, Cisco equivalent for few ports would be (using equivalent port number on one Catalyst access switch) :
! port 1 - tagged on vlan 2-4 but no untagged on vlan 1
int git1/0/1
! vlan 1 is not allowed so, as it is default native vlan, non tagged traffic will be dropped as HP config expect.
switchport trunk allowed vlan 2-4
! port 3 - tagged on vlan 3 but no untagged on vlan 1
int git1/0/3
! port 5 - untagged vlan 4 (and no untagged vlan 1)
int git1/0/5
! port 6 - tagged on vlan 2-4 but untagged on vlan 1
int git1/0/6
! vlan 1 is allowed so, as it is default native vlan, non tagged traffic will be accepted as HP config expect.
switchport trunk allowed vlan 1-4
! next command is optionnal as vlan 1 is native per default
! switchport trunk native vlan 1
Moreover, you might add next commands depending your needs :
* on older Catalyst switches, set the type of trunking : switchport trunk encapsulation dot1q
* disable DTP to avoid port negociate its trunking state : switchport nonegotiate
* on a port facing a direct host, activate STP portfast to avoid convergence timers : spanning-tree portfast or spanning-tree portfast trunk (for tagged ports)
I'm not HP expert, so I hope to not be wrong.
Jérôme
