CoPP on my c6880x
johndox
@Jon Marshall
Pls, I need your guidance,
exceeded 433965808 packets action: drop      <<- Please can you tell me how to find out the exact type of Packets dropped, I know the class-map doesn't have any corresponding ACL match statement
OR is HSRPv2 packets matched on this default class-map( class-copp-mcast-v4-data-on-routedPort (match-any)) ? Then if not, which then.
Thanks in advance
switch#show policy-map interface
 Control Plane Interface
  Service-policy input: policy-default-autocopp
  Hardware Counters:
    class-map: class-copp-mcast-v4-data-on-routedPort (match-any)
      Match: none
      police :
        10 pps 1 limit 1 extended limit
      Earl in slot 5 :
        433965808 packets
        5 minute offered rate 9 pps
        aggregate-forwarded 0 packets
                            action: drop
        aggregate-forward 0 pps exceed 9 pps
  Software Counters:
    Class-map: class-copp-mcast-v4-data-on-routedPort (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: none
        0 packets, 0 bytes
        5 minute rate 0 bps
      police:
         rate 10 pps, burst 1 packets
          conformed 0 packets, 0 bytes; action:
            drop
          exceeded 0 packets, 0 bytes; action:
            drop
          conformed 0 pps, exceeded 0 pps
switch#show ver
Cisco IOS Software, c6880x Software (c6880x-ADVENTERPRISEK9-M), Version 15.4(1)SY1, RELEASE SOFTWARE (fc8)
0 Replies 0
