Copper Network Module
shiva
Community Member
Hi, does 3650 or 3850 supports 10GT Copper module. please share part code if available. Thanks shiva
Joanna -10Gtek
Could you please provide the specific model of these two Cisco swithes?
Whether 10G or 1.25G Switch, we have the corresponding module.
10Gtek Online Store: www.sfpcables.com
According to Cisco 10-Gigabit Ethernet Transceiver Modules Compatibility Matrix it looks like 3650 & 3850 both supports 10-Gigabit Ethernet Transceiver Module.
Part Numbers:
SFP-H10GB-CU1M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
Joseph W. Doherty
See SFP-H10GB-xxx components in:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc458157387
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc458157390
Ganesh Hariharan
shiva
Hi Shiva,
Apart from below threads , You can have look on compatibility matrix for switches supported.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc458157384
Hope it Helps..
-GI
