nexus span session
Mary
Level 5
Level 5
I configured below span session in Nexus 1000v:
monitor session 2
source interface e2/1-2
source vlan 3,6-8 tx
filter vlan 3-5,7
destination int E2/5
is the above configuration correct?
Julio E. Moisa
Yes but filter should be used if you are monitoring for example a trunk so it will monitor only the vlans configured passing through it, also please check these links:
https://virtuallymikebrown.com/2013/04/13/how-to-configure-span-on-a-nexus-55xx/
https://www.netfort.com/blog/setup-span-ports-cisco-nexus-switches/
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
so the source e2/1-2 must be trunk? can the destination port in the other slot, for example ge3/0/1 rather than ge2/0/5(not e2/5, we are using nexus)? thanks
if you have a interface trunk and many vlans are passing through it but you want to monitor only certain vlans, you should include on the span session the filter command.
Ganesh Hariharan
monitor session 2
filter vlan 3-5,7
Apart from Julio message , have a look on the below link for pre-requisite for SPAN.
Nexus 1000V SPAN Requirement
Hope it Helps..
-GI
