Copper SFP for C9300X-24Y-A
inhamit
Hi, I am looking for Copper SFP for C9300X-24Y-A switch to insert in downlink ports. Please suggest.
Hello @inhamit,
You're welcome.
Here: https://tmgmatrix.cisco.com/
Best regards
6 Replies 6
Leo Laohoo
What speed?  1-, 10- or 40 Gbps?
inhamit
Please suggest for 1 and 10 both.
1 Gbps:  GLC-T or GLC-TE
10 Gbps:  SFP-10G-T
M02@rt37
Hello @inhamit,
For C9300X-24Y-A model, you can use the Cisco SFP-10G-T-X module, which is a copper SFP  transceiver designed for 10 Gigabit Ethernet connectivity over copper cabling. It supports a maximum cable length of up to 30 meters.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
Best regards
Hi M02@rt37, Thanks. Do we have any compatibility matrix link where I can check type of SFP's supported with the particular switch model?
Hello @inhamit,
You're welcome.
Best regards
