Copy flash TFTP Error (timed out) - solarwinds
terrelstinnett
I recently posted this same issue the other day, using TFTPd32. Now i am pretty close to fixing it.
I do have a different setup; my pc ethernet port is broken so I am using an ethernet/usb adapter.
I am attempting to backup my IOS from a 3550 switch to my PC.
This is the error I am getting.
Switch#copy flash tftp
Source filename [c3550-ipbasek9-mz.122-25.SEB4.bin]?
Address or name of remote host []? 192.168.1.50
Destination filename [c3550-ipbasek9-mz.122-25.SEB4.bin]?
%Error opening tftp://192.168.1.50/c3550-ipbasek9-mz.122-25.SEB4.bin (Timed out)
I can ping both ways.
Switch#show int vlan1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 0012.4339.a880 (bia 0012.4339.a880)
  Internet address is 192.168.1.100/24
Ping statistics for 192.168.1.100:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
Switch#ping 192.168.1.50
From PC:
Sending 5, 100-byte ICMP Echos to 192.168.1.50, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Once again I am plugged in through an ethernet/usb adapter.
I am using Solarwinds, services are STARTED.
Any help would be appreciated..
5 Replies 5
vmiller
Level 7
Level 7
Are you on the same subnet as the router?
If not, you may need the ip helper-address configured.
yes we are on the same subnet.
PC
192.168.1.50
255.255.255.0
default gateway 192.168.1.100
switch
int vlan1 192.168.1.100
int fa0/1
switchport mode access
switchport access vlan 1
and no i dont know how to do that helper address.
In your case it would not make a difference.
Helper address is good for getting udp traffic (like tftp) routed correctly.
wonder if you need to have the file created (even if its empty) for the copy to work?
i dont really know. i just downloaded the server. the switch is a week old and seems to work fine in my labs.
Make sure the file is in the correct directory on your Tftpd32.
From your Tftpd32, when you click on "sh dir" are you able to see the file. If not then that is your issue..
