Cross-stack Etherchannel 20Gb and STP on 3750x
i want to realize a 20gb ring stp with 6  3750x stacked by 2.
I want to install 2 3750x stacked configured in hsrp mode with other 2 3750 stacked. These 2 different stack are interconnected by a cross-stack etherchannel 20Gb  fiber. On the other side of the room i want to create a new stack with 2 3750x with cross-stack etherchannel 20gb connected with the previous 2 stacks. So, in total 3 different cross-stack etherchannel 20Gb stacks interconnected creating a ring stp of 20 Gb.
This configuration in your opinion can work correctly?
Pierluigi
acampbell
As it sounds like you will be installing a physical ring the best practice would be
to avoid the chances of STP loops
May be try to configure something like this :-
                                    2x10GB AS PORT CHANNEL
3750X-STACK1===================================3750X-STACK2
STP ROOT ODD VLANS                                        STP ROOT EVEN VLANS
HSRP ACT ODD VLANS                                        HSRP ACT EVEN VLANS
      ===============3750X-STACK3====================
2x10GB AS PORT CHANNEL            2x10GB AS PORT CHANNEL
Alex
Pleae rate useful posts
Regards, Alex. Please rate useful posts.
Thanks for your answer. You understand correctly, but i attach a jpg to axplain the final configurazion.
In your opinion this configuration can work correctly or not? There may be some problems?
Pierluigi
Pierluigi
I do not see any issue with your set up.
But as I showed above it is better to design & config with loop avoidance
STP root bridge selected for each vlan
Something like this :-
SWITCH-1 (PRIMARY FOR ODD VLANS)
spanning-tree mode rapid-pvst
spanning-tree vlan 1,3,5,7,9  priority 8192
spanning-tree vlan 2,4,6,8,10  priority 16384
SWITCH-2 (PRIMARY FOR EVEN VLANS)
spanning-tree vlan 2,4,6,8,10  priority 8192
spanning-tree vlan 1,3,5,7,9  priority 16384
SWITCH -3 Leve priority as default 32768
Alex
  Ok,
thanks for your support.
Pierluigi
