Copy FLASH to USBFLASH0...Simple Question need answered
techsgtdan
I would like to copy all folder/files from flash to usbflash.  When I receive a new router to configure, I would like to use my usb-stick to copy everything from flash, including that ccpexp folder with many sub-folders, to my usb.  Can someone assist with how to perform or options?
Hello
Format the usb first.from a pc
then from the router:
copy flash:*.* usbflash0:
res
Paul
Kind Regards
Paul
Ah...I tried that several times with nno luck.  This should be an easy thing to due.  I know someone will tell me to use ftp or tftp but I really don't think I have to if the router has a usb port.  Doing files individualy will work, but if a router has many files in flash then a simple COPY command should be enough.  Am I missing something?
Hello
when you say it doesn't work - what is the issue?
res
paul
Kind Regards
Paul
Archive the files from the router and target the USB flash as the destination.
