copy ios from switch to tftp error "%error reading flash:xxxxxxxxxxxxxxxxxxxxxxxxxx.bin (is a directory)"
aman.kamboj
I have cisco me3400 series switch with me. I am not able to copy ios from switch to tftp server instead i can copy running-config and other file but not ios file. Error shown is as below:
Mark Malone
Try this
http://egementanirer.blogspot.com/2012/10/error-reading-flash-is-directory.html
thanks for reply but couldn't get the solution
can you elaborate a bit more on what didn't work , the reason its not allowing you transfer it because its in a directory in flash  , when you CD to it you should see the .bin file and be able to transfer that as that's not in a directory ?
its the same method , you got to break it out of the directory 1st
http://www.techexams.net/forums/ccna-ccent/7525-copy-flash-tftp-when-ios-image-folder.html
