copy sh run from one nexus to another
robertkwild
Hi all,
I have 2 nexus 7000 and about 11 fex switches,
Each fex is connect to each 7000 via port channel consisting of two fibres cables, so one fex has got one Port channel going to Nexus one and also going to nexus two
There both labeled on both nexus's as the same port Chanel, IE po blah...
Thing is Nexus one has only got the configs for them all, is there a way to grab the configs and save it to nexus 2 as well, I thought of a sh run to grab the config
Rob
Mark Elsen
 - You can easily copy the running config of a nexus to an external repository with scp, then import it on another from the same repository , -> meaning , edit it first on the repository and import only what is relevant for the targeted nexus.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
robertkwild
so on the nexus that hasnt got the relevant po configs, copy its running config via tftp, then edit it, copy JUST the po config into it (from the other nexus that has got the po) and then copy its new running config back, will this work
No, follow my first reply only.M.
       Beauty and terror
      Just keep going
       No feeling is final
