Core Cisco 4006 switch
muraripadhan
If i remove the power cable from Cisco 4006 switch and fixed the switch another place then insert the power cable then what will happen?
Means is there any problem occur in Cisco switch ?
And suggest me , I want to shift my network rack one place to another place. So what are the step for removing the switch and fixed it please suggest me?
Jon Marshall
It has been a while since I used one of those switches.
Firstly before doing anything save the configuration. If you are running CatOS that should be saved automatically but IOS on a L3 card won't.
If you are looking to move it to another rack then you may need to rerun all the network cables which can be a tedious job and you would also want to label them so you know which port they are connected to on which module.
Once you have done that you can power down the switch, remove network cables and power cable, relocate switch, connect the network cables and power lead back and then power up the switch.
By far the most time consuming are the network cables depending on how many you have.
Jon
Thanks Sir giving me advice
Thanks & redgards
Murari Mohan Padhan
