core switch config help with client default gateway
keith.magyar1
Community Member
I have clients on an edge switch that cannot seem to be able to use a default gateway of 10.3.92.254. The current state is one that we are migrating from which has everthing in vlan1. Those clients use 172.16.0.2. Can anyone tell me what am I missing?
Two congifs copied below;
Edge Switch Config - ws-2960-24pc-s
hostname S-DAYACCNT
boot-start-marker
ip domain-name globe-motors.com
ip name-server 172.16.200.14
ip name-server 172.16.200.46
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
lldp run
ip ssh authentication-retries 5
interface FastEthernet0/1
description Client PC
switchport access vlan 119
switchport mode access
switchport voice vlan 2
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
description ADMIN FAX
switchport access vlan 2
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
description 3RD FLOOR CONF ROOM DATA PORT
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
description ACCT FAX ATA
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,2,11,75,119
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
ip address 172.16.0.29 255.255.0.0
no ip route-cache
interface Vlan119
description US-DAY-GEN
ip address 10.3.92.29 255.255.255.0
no ip route-cache
ip default-gateway 172.16.0.2
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
logging 172.16.200.124
snmp-server community monitor RO
snmp-server community CactiMonitoring RO
snmp-server location Dayton,OH
control-plane
ntp clock-period 36029817
ntp server 172.16.200.14
end
S-DAYACCNT#
Core Switch Config WS-C3750X-48P-S
hostname USDAYCORE
boot-start-marker
boot-end-marker
enable secret 5 $1$sat3$INN4OF0IT/nbLHXHcuqOY/
username core privilege 15 secret 5 $1$
username misadmin privilege 15 password 7
no aaa new-model
clock timezone EST -5
switch 1 provision ws-c3750x-48p
system mtu routing 1500
ip routing
ip device tracking
port-channel load-balance src-dst-ip
lldp run
class-map match-all VOIP
policy-map Voice
interface Port-channel1
description Barracuda LAG
interface Port-channel2
description DAYIAP2_DRAFT01
switchport trunk allowed vlan 1,2,21,75
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet1/0/1
description DAYIAP3
switchport trunk allowed vlan 1,2,11,21,75,119
spanning-tree portfast disable
interface GigabitEthernet1/0/2
description MIS Desktop PC
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
description WIFI AP DAYIAP2
interface GigabitEthernet1/0/6
description AT&T MPLS NETWORK
interface GigabitEthernet1/0/7
description Darren Taylor_202
interface GigabitEthernet1/0/8
description DAYIAP5
interface GigabitEthernet1/0/9
description DAYBACKUP_BARRACUDA
channel-group 1 mode active
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
description test
interface GigabitEthernet1/0/12
description DAYIAP2_DRAFT1
interface GigabitEthernet1/0/13
description DAYIAP4
interface GigabitEthernet1/0/14
description MIS Client PC
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
description S-Day1Flr1
interface GigabitEthernet1/0/17
description Guest_Wifi VLAN 75
switchport trunk allowed vlan 1,11,75,119
interface GigabitEthernet1/0/18
switchport trunk allowed vlan 1,11,119
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
description S-DayTestLab
switchport trunk allowed vlan 1,2,11,25,75,119
interface GigabitEthernet1/0/22
description Darren Taylor on 119
interface GigabitEthernet1/0/23
duplex full
interface GigabitEthernet1/0/24
description Connection to 2800 Router
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
switchport trunk allowed vlan 1,2,11,119
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
description Meraki LAN2
switchport trunk allowed vlan 1,2,6,10,11,18,20,25,30,75,119,122
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
description GuestTest
switchport access vlan 75
interface GigabitEthernet1/0/37
description WIFI AP DAYIAP6
interface GigabitEthernet1/0/38
description OWNCLOUD
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
description S-DAYACCT
interface GigabitEthernet1/0/41
description S-DayLab2Flr
interface GigabitEthernet1/0/42
description Uplink to S-Day3Flr
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
description DAYIAP1_AIRHND1
interface GigabitEthernet1/0/45
description PRIMARY IPLEX
interface GigabitEthernet1/0/46
description BACKUP IPLEX
interface GigabitEthernet1/0/47
description SKYCUBE_CBTS_SIP
interface GigabitEthernet1/0/48
description SANNetwork Trunk
switchport trunk allowed vlan 1,2,11,25,119,200
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
description Data Network
ip address 172.16.0.2 255.255.0.0
interface Vlan2
description Voice Network
ip address 192.168.16.1 255.255.255.0
interface Vlan5
description 3CX_Phone
ip address 192.168.5.1 255.255.255.0
interface Vlan11
description US-DAY-SRV
ip address 10.3.1.254 255.255.255.0
interface Vlan19
description Foundry
no ip address
interface Vlan20
description TestEnv
ip address 172.20.0.1 255.255.0.0
ip access-group DenyVLAN out
interface Vlan21
description US-DAY-GST
no ip address
interface Vlan25
ip address 172.25.0.1 255.255.0.0
interface Vlan75
description Guest Wireless
ip address 192.168.75.1 255.255.255.0
ip access-group RestrictGuestWireless in
interface Vlan119
ip address 10.3.92.254 255.255.255.0
interface Vlan200
description EMC_SAN_NETWORK
ip address 172.200.0.1 255.255.0.0
router eigrp 2275
network 172.16.0.0
eigrp stub connected summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.11
ip route 10.10.18.0 255.255.255.0 172.16.0.3
ip route 10.10.19.0 255.255.255.0 172.16.0.3
ip route 10.10.21.0 255.255.255.0 172.16.0.3
ip route 10.10.22.0 255.255.255.0 172.16.0.3
ip route 10.140.1.0 255.255.255.0 10.3.1.1
ip route 10.140.92.0 255.255.255.0 10.3.1.1
ip route 72.75.211.132 255.255.255.255 10.10.1.1
ip route 172.19.0.0 255.255.0.0 172.16.0.3
ip route 172.22.0.0 255.255.0.0 172.16.0.6
ip route 172.23.0.0 255.255.0.0 172.23.0.1
ip route 172.23.253.0 255.255.255.0 172.16.0.6
ip route 172.25.1.0 255.255.255.0 172.16.0.3
ip route 172.31.0.0 255.255.0.0 172.16.0.6
ip route 172.32.0.0 255.255.0.0 172.16.0.10
ip route 172.200.0.0 255.255.0.0 172.16.0.6
ip route 192.168.4.0 255.255.255.0 172.16.0.3
ip route 192.168.18.0 255.255.255.0 192.168.16.5
ip route 192.168.19.0 255.255.255.0 192.168.16.3
ip http server
ip access-list extended RestrictGuestWireless
permit ip 192.168.75.0 0.0.0.255 host 172.16.0.2
permit ip 192.168.75.0 0.0.0.255 host 172.16.0.9
permit ip 192.168.75.0 0.0.0.255 host 172.16.0.15
permit ip host 172.16.6.14 192.168.75.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 172.16.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.18.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.19.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.23.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.21.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.200.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 10.10.18.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.19.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.20.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.21.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.22.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 192.168.16.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 192.168.18.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 192.168.19.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 192.168.17.0 0.0.0.255
permit ip any any
permit ip 192.168.75.0 0.0.0.255 host 192.168.75.2
permit ip host 192.168.75.0 0.0.0.246 172.16.0.9
permit ip host 192.168.75.0 0.0.0.253 192.168.75.2
ip sla enable reaction-alerts
logging 172.16.6.14
snmp-server community private RO
snmp-server location dayton,oh
snmp-server contact [email protected]
snmp ifmib ifindex persist
line con 0
line vty 0 4
session-timeout 120
exec-timeout 120 0
login local
transport input telnet ssh
line vty 5 15
session-timeout 120
exec-timeout 120 0
login local
ntp clock-period 36027188
ntp server 172.16.200.46
end
USDAYCORE#
Any help is appreciated.
6 Replies 6
Reza Sharifi
Try deleting
first and than add
ip default-gateway 10.3.92.254
and than test.
If I do that, does that mean I need to add
ip default-gateway 10.3.1.254 as well for servers that are on vlan11?
No, all you need is one gateway. Looking at the switch config you have the following configured which means you want to switch from vlan 1 to vlan 119.  If this is the case than you need to change the gateway on that switch to be in 10.3.92.254 which is the SVI on the core switch. Is that what you are trying to do?
interface Vlan1
no ip route-cache
interface Vlan119
no ip route-cache
Yes, this is what I want to do. But what gateway would I give something in VLAN11 which is 10.3.1.0/24? I have a Meraki MX100 with vlan11 clients using the gateway at the MX appliance 10.3.1.1. Shouldnt I have a gateway to use at my core switch? To lighten the traffic on the MX by keeping local LAN requests concentrated at the core?
Remember, the default gateway on the switch is to reach the switch as a device, not to assist clients.
I do see you haven't added the new network to EIGRP 2275, so those clients on the new 10.3.92.x network won't get far; unless upstream you have static routes (which you probably DON'T want to do).
Clients are getting the proper gateway assigned, that matches their IP address subnet; or do clients have static IP addresses?  I don't see helper-addresses defined.
Hello
The core switch will provide the inter-vlan routing, And I can see you have the L3 svi for vlan 1, 11, 119 among others, so as long as the vlan database is propagated to the access switches and allowed across the trunks and the access ports are assigned to the correct access vlan all should be good.
sh vlan brief
sh int trunk
You only require one management L3 address on the access switches and ip routing  should disabled and the hosts should have correct addressing relative to L3 svi of the core switch as their D/G
No ip routing ( access switches)
Lastly on the core switch you will need to add the L3 addressing into the eigrp for advertising the lan subnets, Here I would be more specific with that advertisement and not use classful network statements but instead more specific ones.
router eigrp 2275
no auto summary
network 172.16.0.2 0.0.0.0
network 192.168.16.1 0.0.0.0
network 192.168.5.1 0.0.0.0
network 10.3.1.254 0.0.0.0
network 172.25.0.1 0.0.0.0
network 192.168.75.1 0.0.0.0
network 10.3.92.254 0.0.0.0
network 172.200.0.1 0.0.0.0
no network 172.16.0.0
res
Paul
Kind Regards
Paul
