Correct cable for
MARLIE JOSEPH
Frequent Visitor
Frequent Visitor
Hello Experts!
I am looking for the cable and baud rate for connecting to WS-SUP32-10GE-3B module. On the Cisco website (http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/03instal.pdf) it says that sup module for 6513 uses a rollover cable at 9600 8 none 1. However,this did not work with my current sup32 module. Does anyone have a suggestion?
Thanx
keegan.holley
Level 3
Level 3
Computers usually have a DB-9 serial port are you sure the adapter you are using has the correct pinouts. If you have any doubts the standard one piece console cable used for other cisco devices should work.
Thanks for your input. Issue was the standard one piece console cable was bad. I replaced it with a db9 connector and rollover cable and was able to connect.
