Correlation Between MAC ACL & IP ACL!
fntowo2009
In our network, we use MAC ACLs to control access to our network.
We have 2 interconnected distribution switches. HSRP runs on both switches and an IP ACL is activated on the SVIs in the inbound direction.
We found that the IP ACL applied to the SVI on the active gateway (SW1) is bypassed if the following conditions are met:
              - The host is directly connected to the active gateway
              - A MAC ACL is applied to the port
Below is an excerpt of the relevant configuration for VLAN 200 on SW1.
interface GigabitEthernet0/41
switchport access vlan 200
switchport mode access
mac access-group allowed-MAC-M-WIRELESS in
no cdp enable
spanning-tree portfast
spanning-tree guard root
interface Vlan200
  ip address 192.168.2.2 255.255.255.0
ip access-group acl_Vlan_Filter in
  no ip unreachables
  standby 2 ip 192.168.2.1
  standby 2 priority 200
  standby 2 preempt
Is the correlation we are seeing normal?
Thanks in advance for your feedback!
Frank
rsimoni
Hi Frank,
please share info about how those ACLs are configured (what they are supposed to do) and what you see instead.
You did not give us enough info to tell whether what you see is expected or not.
Also add info about switch model and IOS used.
Quick notation, on cisco switches MAC ACL are meant for NON IP traffic only (i.e. they don't affect IP traffic).
Riccardo
