CP 2.6 viewing problem
cpatcisco
I am a Cisco novice.  I have used Configuration a few times with success.  Now I am trying to bind a few DHCP addresses, but the window that opens does not display any action buttons, so I can't add new bindings.  I have tried stretching the window, but that just increases the white space - I still don't get any buttons and there are no scroll bars.
This problem occurs in other windows, like the NAT window, where the little drawing is cut off and other widows too.
Has anyone else encountered this?
Do you know of any remedies?
Charles Pinsky.
dodoya27
see Release Notes for Cisco Configuration Professional 2.6
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_professional/v2_6/rlsnts/ccp_rel_notes.html
Bug ID : CSCtr24865
The security/routing screens are not visible fully if the screen display settings is set to 150%
Additional Information
Symptom The security and routing screens are not visible fully.
Conditions This issue occurs when you select Control Panel > All Control Panel Items > Display and set the display settings to 150%.
Workaround Select the Control Panel > All Control Panel Items > Display and set the display settings to 100%.
dodoya27
Bug ID : CSCtr24865
Thanks you very much for your helpful reply.  I had given up hope of getting the solution.
gondal khan
it doesnt works for me
after doing this i am gettng the screen whic says retrieving port ..  and the progressbar is there ..
i am using 2.7
