Cpu high in 3650x
bluesea2010
Level 5
Level 5
Hi I am getting cpu hike in 3650x
 PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
4 1267300 56731 22338 11.34% 1.61% 1.31% 0 Check heaps
145 10688400 2010542 5316 9.26% 9.38% 9.72% 0 Hulc LED Process
66 4284063 641473 6678 4.15% 4.32% 4.34% 0 RedEarth Tx Mana
65 1914980 1066531 1795 2.07% 1.96% 1.96% 0 RedEarth I2C dri
205 2530633 453821 5576 1.59% 2.26% 2.29% 0 Spanning Tree
106 1654437 93772 17643 1.27% 1.59% 1.59% 0 hpm counter proc
218 397031 93777 4233 0.63% 0.72% 0.73% 0 PI MATM Aging Pr
87 382738 2631824 145 0.47% 0.60% 0.61% 0 HLFM address lea
134 91080 468158 194 0.31% 0.14% 0.13% 0 Hulc Storm Contr
155 337128 19151 17603 0.31% 0.32% 0.31% 0 HQM Stack Proces
89 173093 2632179 65 0.31% 0.19% 0.18% 0 HLFM address ret
258 118826 210908 563 0.15% 0.16% 0.14% 0 Marvell wk-a Pow
103 437271 1222006 357 0.15% 0.43% 0.41% 0 hpm main process
190 109470 936650 116 0.15% 0.16% 0.16% 0 MDFS MFIB Proces
303 158 194 814 0.15% 0.20% 0.04% 1 Virtual Exec
How to figure it out
5 Replies 5
Reza Sharifi
Can you post the output of "sh processes cpu | exclude 0.00"command?
PC_199#sh processes cpu | ex 0.00%
CPU utilization for five seconds: 28%/0%; one minute: 29%; five minutes: 30%
4 1277820 57206 22337 0.47% 1.15% 1.19% 0 Check heaps
65 1932201 1075877 1795 2.07% 1.94% 1.96% 0 RedEarth I2C dri
66 4322121 647085 6679 4.47% 4.40% 4.37% 0 RedEarth Tx Mana
87 386747 2654688 145 0.79% 0.35% 0.38% 0 HLFM address lea
89 175261 2655042 66 0.63% 0.23% 0.19% 0 HLFM address ret
103 441490 1232717 358 0.47% 0.42% 0.43% 0 hpm main process
106 1669057 94595 17644 1.59% 1.62% 1.63% 0 hpm counter proc
145 10773182 2028295 5311 8.62% 10.12% 9.83% 0 Hulc LED Process
155 340075 19319 17603 0.31% 0.33% 0.31% 0 HQM Stack Proces
185 5856 28543 205 0.15% 0.04% 0.03% 0 IP Input
205 2552288 456791 5587 1.91% 2.31% 2.30% 0 Spanning Tree
218 403386 94600 4264 0.79% 0.74% 0.74% 0 PI MATM Aging Pr
258 120003 212759 564 0.47% 0.15% 0.14% 0 Marvell wk-a Pow
303 6720 1498 4485 0.15% 0.06% 0.34% 1 Virtual Exec
The CPU is running fine. 28% or 30% is normal.
Can you tell me how did u reach in this conclusion
Based on number of years I have been working with Cisco switches, I can tell you that is completely normal. Cisco switches usually run with higher CPU than Cisco routers.
