cpu utilisation error on cisco 2911sec-k9
zeuscyril
Level 4
Level 4
hi all,
the cisco router is giving me high cpu utilization in ip nat ager
here is my system details and logs
PLEASE PROVIDE ME SOME SOLUTION I UPGRADED TO LATEST ALSO NO USE.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(3)T, RELE
ASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 23-Mar-12 16:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
AEDXBRT01 uptime is 2 hours, 24 minutes
System returned to ROM by reload at 13:00:32 UAE Wed Jun 6 2012
System image file is "flash0:c2900-universalk9-mz.SPA.152-3.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FCZ1605706B
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FCZ1605706B
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
"sh process cpu "
CPU utilization for five seconds: 2%/1%; one minute: 15%; five minutes: 66%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1        3772       49967         75  0.00%  0.03%  0.06%   0 Chunk Manager
   2         280        1751        159  0.00%  0.00%  0.00%   0 Load Meter
   3           0           2          0  0.00%  0.00%  0.00%   0 VTEMPLATE Backgr
   4           0           1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   6        8632        1311       6584  0.00%  0.10%  0.10%   0 Check heaps
   7           8         147         54  0.00%  0.00%  0.00%   0 Pool Manager
   8           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   9           0           2          0  0.00%  0.00%  0.00%   0 Timers
  10           0          27          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  11           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  12           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  13       10648         147      72435  0.00%  0.09%  0.10%   0 Licensing Auto U
  14        8128        8670        937  0.00%  0.06%  0.05%   0 Environmental mo
  15           4        1749          2  0.00%  0.00%  0.00%   0 IPC Event Notifi
  16           0         147          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  17           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  18           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  19           4        8368          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  20          24        8368          2  0.00%  0.00%  0.00%   0 IPC Deferred Por
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  23           0         502          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  24           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  25           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  26           0         880          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  27           4        1753          2  0.00%  0.00%  0.00%   0 IPC Loadometer
  28           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  29           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  30           0           1          0  0.00%  0.00%  0.00%   0 PPPoE SW Flow Co
  31           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  32        1784       28092         63  0.00%  0.01%  0.00%   0 ARP Input
  33          20        8959          2  0.00%  0.00%  0.00%   0 ARP Background
  34           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  35           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  36           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  37           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  38           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  39           4         295         13  0.00%  0.00%  0.00%   0 DDR Timers
  40           4           3       1333  0.00%  0.00%  0.00%   0 Entity MIB API
  41        2068          29      71310  0.00%  0.00%  0.00%   0 PrstVbl
  42           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  43           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  44           0           2          0  0.00%  0.00%  0.00%   0 SMART
  45           4           1       4000  0.00%  0.00%  0.00%   0 RF SCTPthread
  46           0           1          0  0.00%  0.00%  0.00%   0 CHKPT RG SCTPthr
  47           0           1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  48          48        8753          5  0.00%  0.00%  0.00%   0 GraphIt
  49           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  50           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  51           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  52           0           2          0  0.00%  0.00%  0.00%   0 REVT background
  53           0           1          0  0.00%  0.00%  0.00%   0 REVENTON Cleanup
  54           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  55           4        1594          2  0.00%  0.00%  0.00%   0 Net Background
  56           4           2       2000  0.00%  0.00%  0.00%   0 IDB Work
  57           0          42          0  0.00%  0.00%  0.00%   0 Logger
  58          28        8670          3  0.00%  0.00%  0.00%   0 TTY Background
  59           4          12        333  0.00%  0.00%  0.00%   0 RF Slave Main Th
  60           4           6        666  0.00%  0.00%  0.00%   0 IF-MGR control p
  61           0           9          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  62           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  63           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  64           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  65           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
  66           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  67           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  68           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  69           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  70           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  71           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  72           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  73           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  74           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  75           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  76           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
  77           0           1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
  78           0           1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
  79           0          78          0  0.00%  0.00%  0.00%   0 TDM Management
  80           0          12          0  0.00%  0.00%  0.00%   0 RF Master Main T
  81           0           7          0  0.00%  0.00%  0.00%   0 RF Master Status
  82          20         402         49  0.00%  0.00%  0.00%   0 Net Input
  83          48        1777         27  0.07%  0.00%  0.00%   0 Compute load avg
  84        1256         308       4077  0.00%  0.01%  0.00%   0 Per-minute Jobs
  85         376        9054         41  0.07%  0.03%  0.02%   0 Per-Second Jobs
  86           0           1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  87           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  88           0          50          0  0.00%  0.00%  0.00%   0 Transport Port A
  89          24        2131         11  0.00%  0.00%  0.00%   0 HC Counter Timer
  90           0           2          0  0.00%  0.00%  0.00%   0 SM Monitor
  91           0           2          0  0.00%  0.00%  0.00%   0 Bryce I2C CMD Qu
  92           0           2          0  0.00%  0.00%  0.00%   0 SM Installer
  93           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  94           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  95           0           1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  96           0           1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  97           0           2          0  0.00%  0.00%  0.00%   0 ESWPPM
  98           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  99           0           2          0  0.00%  0.00%  0.00%   0 ESWILPPM
100           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
101           0           2          0  0.00%  0.00%  0.00%   0 DXMRVL
102           0           1          0  0.00%  0.00%  0.00%   0 esw_mrvl mat que
103           0           2          0  0.00%  0.00%  0.00%   0 ehwic_eswge Proc
104           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
105           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
106           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED Identity
107           8         160         50  0.00%  0.00%  0.00%   0 EEM ED ND
108           0           2          0  0.00%  0.00%  0.00%   0 UCSE Monitor
109           8        8676          0  0.00%  0.00%  0.00%   0 Ether-Switch RBC
111           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
112           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
113           0         293          0  0.00%  0.00%  0.00%   0 Call Management
114           4           2       2000  0.00%  0.00%  0.00%   0 USB Startup
115           0           1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
116         524       17457         30  0.07%  0.03%  0.02%   0 BPSM stat Proces
117           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
118         116       52148          2  0.00%  0.00%  0.00%   0 Ethernet Timer C
119        1004      957552          1  0.15%  0.16%  0.10%   0 Ethernet Msec Ti
120           0           2          0  0.00%  0.00%  0.00%   0 Auth Manager
121           0           1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
122           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
123           0           1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
124           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
125           0           2          0  0.00%  0.00%  0.00%   0 CMD HANDLER
126           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
127           0           1          0  0.00%  0.00%  0.00%   0 SFF8472
128          20        8673          2  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
129           0         874          0  0.00%  0.00%  0.00%   0 EtherChnl
130           0           2          0  0.00%  0.00%  0.00%   0 call_home_les_oi
131           0           1          0  0.00%  0.00%  0.00%   0 SMI Director DB
132           0           1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
133           0           1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
134           0           2          0  0.00%  0.00%  0.00%   0 RG Faults Timer
135           0           2          0  0.00%  0.00%  0.00%   0 RG Protocol Time
136           4           2       2000  0.00%  0.00%  0.00%   0 RG Transport Tim
137           0           1          0  0.00%  0.00%  0.00%   0 RG VP
138           0           2          0  0.00%  0.00%  0.00%   0 RG AR
139           0           3          0  0.00%  0.00%  0.00%   0 CTS CORE
140           0           3          0  0.00%  0.00%  0.00%   0 SXP CORE
141           0          74          0  0.00%  0.00%  0.00%   0 DHCP Snooping
142           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
143           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
144           0           2          0  0.00%  0.00%  0.00%   0 AAA Server
145           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
146           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
147           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
148          40        1478         27  0.00%  0.00%  0.00%   0 CDP Protocol
149           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
150           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
151           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
152           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
153           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
154           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
155           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
156           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
157          88      233157          0  0.00%  0.03%  0.01%   0 IPAM Manager
158           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
159          20          46        434  0.00%  0.00%  0.00%   0 IP ARP Adjacency
160           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
161        7556       39939        189  0.07%  0.07%  0.07%   0 IP Input
162           0          15          0  0.00%  0.00%  0.00%   0 ICMP event handl
163           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
164           0          17          0  0.00%  0.00%  0.00%   0 MOP Protocols
165           4           7        571  0.00%  0.00%  0.00%   0 PPP SIP
166           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
167           0           4          0  0.00%  0.00%  0.00%   0 PPP IP Route
168           0           1          0  0.00%  0.00%  0.00%   0 HQF TUNNEL
169          16         114        140  0.23%  0.02%  0.00% 388 Virtual Exec
170           4           5        800  0.00%  0.00%  0.00%   0 SSS Manager
171           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
172           0           3          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
173          88       33999          2  0.00%  0.00%  0.00%   0 SSS Feature Time
174           0           2          0  0.00%  0.00%  0.00%   0 Spanning Tree
175           4          11        363  0.00%  0.00%  0.00%   0 SSM connection m
176           0           1          0  0.00%  0.00%  0.00%   0 WAAS Process
177           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
178           0           1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
179           0          30          0  0.00%  0.00%  0.00%   0 IP Admin SM Proc
180           0           2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
181           0           2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
182           0           2          0  0.00%  0.00%  0.00%   0 Content-scan Pro
183           0         147          0  0.00%  0.00%  0.00%   0 FRR Background P
184           0         174          0  0.00%  0.00%  0.00%   0 CEF background p
185           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
186           0           1          0  0.00%  0.00%  0.00%   0 IPC UDP Input
187          64        8902          7  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
188           0           4          0  0.00%  0.00%  0.00%   0 ADJ background
189           0           3          0  0.00%  0.00%  0.00%   0 Collection proce
190           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
191           0           1          0  0.00%  0.00%  0.00%   0 Critical Auth
192           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
193           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
194           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
195           4           2       2000  0.00%  0.00%  0.00%   0 L2MM
196           0           1          0  0.00%  0.00%  0.00%   0 MRD
197           0           1          0  0.00%  0.00%  0.00%   0 IGMPSN
198           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
199           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
200           0           2          0  0.00%  0.00%  0.00%   0 RG Media Timer
201           0           1          0  0.00%  0.00%  0.00%   0 RG If-Mgr Timer
202           0           2          0  0.00%  0.00%  0.00%   0 Routing Topology
203           0           8          0  0.00%  0.00%  0.00%   0 IP RIB Update
204           0         156          0  0.00%  0.00%  0.00%   0 IP Background
205           0          17          0  0.00%  0.00%  0.00%   0 IP Connected Rou
206           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
207           4         162         24  0.00%  0.00%  0.00%   0 Call Home Timer
208           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
209           0           1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
211           0           3          0  0.00%  0.00%  0.00%   0 Service Routing
212           8           9        888  0.00%  0.00%  0.00%   0 SR CapMan Proces
213           0           1          0  0.00%  0.00%  0.00%   0 SNMP Timers
214           4           3       1333  0.00%  0.00%  0.00%   0 SCTP Main Proces
215          12         583         20  0.00%  0.00%  0.00%   0 TCP Timer
216           0          57          0  0.00%  0.00%  0.00%   0 TCP Protocols
217           0          32          0  0.00%  0.00%  0.00%   0 HTTP CORE
218           0           1          0  0.00%  0.00%  0.00%   0 IUA Main Process
219          40        8697          4  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
220           0           1          0  0.00%  0.00%  0.00%   0 bsm_timers
221           8        8693          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
222           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
223           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
224           0           1          0  0.00%  0.00%  0.00%   0 COPS
225           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
226           0          20          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
227           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
228           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
229           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
230           0           7          0  0.00%  0.00%  0.00%   0 static
231           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
232           0           1          0  0.00%  0.00%  0.00%   0 LAPB Process
233           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
234           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
235          24         870         27  0.00%  0.00%  0.00%   0 QoS stats proces
236           0           2          0  0.00%  0.00%  0.00%   0 HQF Output Shape
237           0           2          0  0.00%  0.00%  0.00%   0 HQF Input Shaper
238           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
239           0           2          0  0.00%  0.00%  0.00%   0 PPP NBF
240           0           2          0  0.00%  0.00%  0.00%   0 SDEE Management
241          76       16660          4  0.00%  0.00%  0.00%   0 Inspect process
243           0         570          0  0.00%  0.00%  0.00%   0 FW DP Inspect pr
244          12       16603          0  0.00%  0.00%  0.00%   0 CCE DP URLF cach
245           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
246           0           1          0  0.00%  0.00%  0.00%   0 IPS Process
247           0           2          0  0.00%  0.00%  0.00%   0 IPS Auto Update
248           0           1          0  0.00%  0.00%  0.00%   0 Select Timers
249          28           2      14000  0.00%  0.00%  0.00%   0 HTTP Process
250           0           2          0  0.00%  0.00%  0.00%   0 CIFS API Process
251           0           2          0  0.00%  0.00%  0.00%   0 CIFS Proxy Proce
252           0           3          0  0.00%  0.00%  0.00%   0 Crypto HW Proc
253           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
254           0         353          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
256           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
257           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
258           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
259           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
260           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
261           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
262           0           2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
263           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
264           4          11        363  0.00%  0.00%  0.00%   0 NIST rng proc
265           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
266           0           3          0  0.00%  0.00%  0.00%   0 Crypto WUI
267           0           1          0  0.00%  0.00%  0.00%   0 EAP Process
268           0           1          0  0.00%  0.00%  0.00%   0 FW_TEST_TRP
269          44       16604          2  0.00%  0.00%  0.00%   0 Timer Library
270           0           2          0  0.00%  0.00%  0.00%   0 Crypto Support
271           0           1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
272           0           1          0  0.00%  0.00%  0.00%   0 IPSECv6 PS Proc
273           0           2          0  0.00%  0.00%  0.00%   0 CSDB Timer proce
274           0           3          0  0.00%  0.00%  0.00%   0 crypto engine pr
275          48          13       3692  0.00%  0.00%  0.00%   0 Crypto CA
276           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
277           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
278        3504         515       6803  0.00%  0.00%  0.00%   0 crypto sw pk pro
279          48        8725          5  0.00%  0.00%  0.00%   0 Crypto IKEv2
280           0           1          0  0.00%  0.00%  0.00%   0 IKEv2 AAA handle
281           0           3          0  0.00%  0.00%  0.00%   0 CRYPTO MAP FREE
282           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
283           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKE Dispa
284           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKMP
285           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
286          12         440         27  0.00%  0.00%  0.00%   0 IPSEC key engine
287           0           2          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
288           0           1          0  0.00%  0.00%  0.00%   0 Crypto ACL
289           0           1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
290           0           1          0  0.00%  0.00%  0.00%   0 IPSec background
291           0           2          0  0.00%  0.00%  0.00%   0 GDOI GM Process
292           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY
293           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY AC
294          24        8777          2  0.00%  0.00%  0.00%   0 Crypto Device Up
295           0           2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
296           0           1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
297           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
298           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
299           0           1          0  0.00%  0.00%  0.00%   0 PM Callback
300           8         703         11  0.00%  0.00%  0.00%   0 dhcp snooping sw
302           0           5          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
303           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
304           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Routing
305           4          35        114  0.00%  0.00%  0.00%   0 EEM ED Syslog
306           0           4          0  0.00%  0.00%  0.00%   0 EEM ED NHRP
307           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Track
308           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Resource
309           0         875          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
310           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
311           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
312           0           1          0  0.00%  0.00%  0.00%   0 WAN Optimization
313           0           1          0  0.00%  0.00%  0.00%   0 IKEv2 FlexVPN Pr
314           4         275         14  0.00%  0.00%  0.00%   0 Crypto cTCP proc
316           4           2       2000  0.00%  0.00%  0.00%   0 VLAN Manager
317           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
318           0           3          0  0.00%  0.00%  0.00%   0 RBM CORE
319           0           3          0  0.00%  0.00%  0.00%   0 CTS credentials
320           8         188         42  0.00%  0.00%  0.00%   0 EEM Server
321           8          33        242  0.00%  0.00%  0.00%   0 Call Home proces
322           0           3          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
323           0           7          0  0.00%  0.00%  0.00%   0 SSH Event handle
324           0           4          0  0.00%  0.00%  0.00%   0 EEM ED CLI
325           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Counter
326           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Interface
327           0           4          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
328           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED None
329           0           4          0  0.00%  0.00%  0.00%   0 EEM ED OIR
330           0           9          0  0.00%  0.00%  0.00%   0 EEM ED RF
331           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED SNMP
332           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
333           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
334           8         152         52  0.00%  0.00%  0.00%   0 EEM ED Timer
335           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Test
336           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED Config
337           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Env
338         468        7365         63  0.00%  0.00%  0.00%   0 DHCPD Receive
339           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Nf
340           0          24          0  0.00%  0.00%  0.00%   0 Syslog
341           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RPC
342           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
343           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
344           0           1          0  0.00%  0.00%  0.00%   0 tHUB
345           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
346           0           2          0  0.00%  0.00%  0.00%   0 Key Proc
347           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
348           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
349           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
350           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
351           4         147         27  0.00%  0.00%  0.00%   0 DFS flush period
352           0           7          0  0.00%  0.00%  0.00%   0 EEM Helper Threa
353     1499060      407192       3681  0.55% 10.40% 61.69%   0 IP NAT Ager
354           0           1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
355        4156      348143         11  0.23%  0.06%  0.01%   0 IP VFR proc
356          44          15       2933  0.00%  0.00%  0.00%   0 l4f mgt task
357           0           1          0  0.00%  0.00%  0.00%   0 L4F OOB Process
358          48        8575          5  0.00%  0.00%  0.00%   0 CFT Timer Proces
359          64       63564          1  0.00%  0.00%  0.00%   0 PPPoE Background
360           0           8          0  0.00%  0.00%  0.00%   0 PPPoE Discovery
361         160      233430          0  0.07%  0.05%  0.02%   0 PPP manager
362         160      233435          0  0.00%  0.02%  0.00%   0 PPP Events
363          12        8734          1  0.00%  0.00%  0.00%   0 Multilink PPP
364           0           2          0  0.00%  0.00%  0.00%   0 Multilink event
366           0          80          0  0.00%  0.00%  0.00%   0 DHCPD Timer
367           0         146          0  0.00%  0.00%  0.00%   0 DHCPD Database
AEDXBRT01#
Giuseppe Larosa
Hello Zeuscyril,
you can use
show proc cpu sorted 1min
to get an ordered list of processes that are taking most  resources
In order to get better help I would suggest to add the router configuration (remove usernames, passwords and substitute public ip addresses for safety) and the output of
show ip nat  translations
because it is possible that the router is performing too many NAT translations and this has an impact on cpu usage
As a starting point in troubleshooting you can use:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
Hope to help
Giuseppe
hi larosa,
there is nothing big configuration ,
i am having dsl line and that router doing just internet and one port forwarding for RDP.
i tried the following commands
ip nat translation max- 10000
it works for some hours and then again ip nat agr percentage of cpu usage going high like 95%
because i dont have static ip also , dynamically it will get ip from isp by dialer dialing.
thanks
cyril
  hi all,
here is my config
