CPU utilization for cat 4500 switch
I am having the Cisco cat 4500 switch in DMZ envirnment.
The switch shows CPU utilization always 60-66%
i tried to see which processes are using more cpu and found processes mentioned below are taking more CPU
54  11969756761882841792        635 47.84% 43.54% 42.10%   0 Cat4k Mgmt LoPri
  53  23507782482141590258       1097  3.51%  4.30%  3.99%   0 Cat4k Mgmt HiPri
in search further on this i found "debug platform packet all receive buffer" required to use on the switch.
So my questions is can i use this command during production hours?
is this commad cause any issue for traffic on switch?
and how to resolve this CPU utilization from Mgmt LoPri
and
Mgmt HiPri?
Thanks & Regards
Yuvaraj karvekar
I've used that command during production time without issues, but well you never know so idepending how critic is the environment, you may want to schedule a MW. Be sure to disable logging console and logging monitor and you should be fine.
Do a show platform health and you will be able to see which processes inside LoPri are consuming more resources.
I will try per you mentioned
Thank you Norberto Salgado for your quick response
You're welcome Yuvaraj.
If the post was helpful please rate or mark as correct.
Thank you.
