CRC Error and input Error how can fix these
mkumailali
FastEthernet0/13 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0004.4d27.66cd (bia 0004.4d27.66cd)
  Description: EDL-P-Box-NO-4
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 250/255, txload 1/255, rxload 1/255
  Keepalive not set
  Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
  Last input 18:52:43, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
  5 minute input rate 12000 bits/sec, 6 packets/sec
  5 minute output rate 24000 bits/sec, 6 packets/sec
     14488019 packets input, 2783320210 bytes
     Received 345346 broadcasts, 0 runts, 0 giants, 0 throttles
     261028 input errors, 259429 CRC, 1599 frame, 0 overrun, 0 ignored
     0 watchdog, 84207 multicast
     19658279 packets output, 3529106068 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
PAD-8-1-10.179#cle
v
30 Replies 30
RachelGomez161999
A CRC error informs you that the cyclic redundancy check has detected damaged or incomplete files. In that case, the matched value of the data and the attached CRC value do not match, resulting in an aborted action (save, copy, read access, etc.) and a corresponding CRC error message.
Ways to Fix the Cyclic Redundancy Check Error
Restart the computer.
Reconnect external drives.
Re-download the file.
Request a new copy.
Install the latest operating system updates.
Scan the drive.
Greeting,
Rachel Gomez
