Creating command IP on switch
waldronks
I currently have to console into one of my switches that uses a private 172.x.x.x address and want to give it a command IP address in order to SSH into it. I'm not sure what the commands would be to do this....any help would be greatly appreciated!!
Jon Marshall
Kristy
To access a switch remotely you need a L3 vlan interface that is up/up with an IP address. Assuming vlan 1 interface on your switch
int vlan 1
ip address 192.168.5.10 255.255.255.0
ip default-gateway 192.168.5.1
where 192.168.5.1 is the L3 routed interface for vlan 1.
Jon
Jon Marshall
Kristy
int vlan 1
Jon
gauravshar
Level 2
Level 2
I'm sorry I'm not able to understand what your requirement is. Do you wish to enable SSH in place of telnet OR trying to access teh switch through console?
I know how to enable SSH or telnet, what I want to know is how to set up the command IP address on the switch so that I no longer have to console into the switch to get into it.
I believe Jon answered my question....thanks Jon!
Ahhhhhhhhhhhhhhhhhhh ... it's called Management IP Address. :)
