Showing results forĀ
Search instead forĀ
Did you mean:Ā
Creating Management Network
gauravdhingra2009
Community Member
I would like to create management network in my environment, currently we have 3750 and act as layer 2 for other vlans(DMZ,Internal), can i create new manemennt vlan that only act as layer 3 ( enable ip routing) or if i enable ip routing  will it affect all other vlan's also?
Please advise, if yes what would be the configuration we need to have in cisco 3750.
thanks
Jon Marshall
thanks
Gaurav
If you enable "ip routing" but don't have L3 vlan interfaces for your internal and DMZ vlans on the 3750 switch then they will continue to route off the firewall so you should be okay.
What is not clear is what are you managing ie. are there other switches in your network you want to put in the same management network ?
Jon
no, i will be using only servers besides these switches to b part of management vlan
Gaurav
Perhaps you could clarify what you mean by management network ?
Do you mean management network for managing network devices or are you referring to a management network for the servers using ILOs etc ?
Jon
